SDA II - Tweeter Questions - Continued...
heroglyphic
heroglyphic Posts: 23
edited October 2007 in Vintage Speakers
Thanks to everyone that helped me in that last thread... I have more more question then I'll know what I'm doing... Here is is:
I am going to upgrade my SDA II's with the RD0-194 tweeters. If I do that, will the CSi5 center channel speaker still be a good timbre match for these modified speakers? The Polk website says that's the one that matches, but once I alter them, they wont sound the same. What should I do?
Thanks again,
John
Post edited by heroglyphic on
  • heroglyphic
    edited October 2007
    Still hoping to get a quick answer to the above question... I want to buy this stuff :-)
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited October 2007
    Yes, it is a good choice. The only better choice if you wanted to get down to it, would be a single monitor series speaker (vintage), ala a Monitor 4, or 5 on it's side (or not) with the same upgraded RDO tweeter.
    Cheers,
    Russ
