Help me i'm Hungry
OSSA
Hola all,
I am a clueless **** when it comes to vinyl but I started collecting some records and now for some reason I want to listen to them. I only have 200 dollars to spend but could anyone recommend a turntable for me with USB.
Also dumb question but can I hook speakers right into it or must I purchase a receiver also?
Any help is very much appreciated!
V/r
OSSA
V/r
OSSA
Post edited by OSSA on
I don't think there is a USB turntable. You will need a receiver and/or some sort of phono pre-amp and amplifier. You could concievebly pull this off in the used market, but it would be tough with a $200 limit.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
USB turntables are cheap junk from what I've seen. An external ADC would work better I would think. The old AR-XA turntables are good starters that can be had for about $40-$90 depending on condition. Cheap and very good TT's. The cartridge is where the money is, though the AR turntables sound good for your basic rock with a Shure M91ED that runs about $90. You do need a reciever or preamp / amp combo for power.
so what your saying is the Cartridge is more important that the TT,
the reason i was asking for a USB is so that i could transfer the music. what i am doing is when i have a cd that is past its prime i am starting to replace it with the LP of it so i have that for home cause i'm starting to realize its alot nicer to sit around a record and talk/have a beer, than a cd player and then i can transfer it to some other format ie cdr or mp3 for my car? so no matter what i need at least a reciever huh?. -
Do a google search for "USB turntable". It brought up a lot of information about those very things. Numark and ION both make as USB T/T plus other companies have soundcards that can work with an existing T/T.Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
thank you
Yes, the cartridge is the most important part of a turntable setup. I guess that needs a little qualification, if you have a truly bad tonearm or a lot of wow, flutter, or rumble in the turntable itself, the best cartridge in the world won't sound good. Generally speaking though, you should invest more in the cartridge than the turntable. A card for your computor that will accept analog signals and convert them to digital (ADC) would be IMHO better than a turntable specifically set up with a USB connection because you could then use any turntable or other analog source to record CD's. Look for a card that has RCA connectors and you can plug your analog source right into the card. You can also get RCA / mini plug adaptors if your card only has mini plug inputs as most do.
what about a technic BD-22 witha shure cartridge?? is that a good table for 60bucks
Why Does Anyone Want To Listen Or "convert" Vinyl Just Get Cd"s Call It A DayHT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
As one of your audio advisors, I strongly suggest you go get a book called "Good Sound" by Laura Dearborn. Get that book and you'll never ask a question like the one about "Can I drive a pair of speakers with a turntable, or do I need a receiver" again. So far, I think it's the best advice you've gotten on this thread.
"An educated consumer is our best customer."
Sy Sims, mens clothier, Route Something or Other, New Jersey -
bigaudiofanatic wrote: »Why Does Anyone Want To Listen Or "convert" Vinyl Just Get Cd"s Call It A Day
There is a lot of good **** on vinyl you can't find on cd. I prefer to just spin the vinyl, but to each his own.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
^ Isn't everything?
Not sure if you ever found what you were looking for....but this came up local to me:
http://nh.craigslist.org/ele/449043105.html -
This is absolutely brilliant. Buy a new LP and then just A/D convert it and burn a CD. Then, you have the best of both worlds!
