Do I Have a Bad Tube????
Early B.
Today I changed out the tube in my Bada CDP. On three occasions, after about 20 minutes, the volume slowly fades out and the music can only be faintly heard on the right speaker. I have to "reboot" the system to get things back to normal, then 20 minutes later, it occurs again. This has never happened before. Can a tube exhibit that kind of behavior or should I look elsewhere?
Thanks.
Thanks.
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Post edited by Early B. on
Dirty pins / socket perhaps.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
You could swap tubes.
"God grooves with tubes." -
Hi Early,
If you do determine it is the tube that I sent you by all means let me know, of course I'll send your money back.
I didn't personally put the one you have in my player after it was tested by tube depot.
I'm no tube expert but is it seated firmly into the pin holes?Analog Source: Rega P3-24 Exact 2 w/GT delrin platter & Neo TT-PSU Digital Source: Lumin U2 w/Roon (NUC) DAC:T+A DAC 200 Phono Preamp: Rega Aria MK3 Preamp: Rogue RP-7 Amp: Infigo Method 6 Speakers: Joseph Audio Perspective 2, Audio Physic Tempo Plus Cables: Cardas Clear Reflection SC/IC, Shunyata PCs Misc: Shunyata Hydra Delta D6, VTI rack, GIK acoustic panels -
phipiper10 --
Not sure if it's the tube yet. PM sent.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
I meant swap in a known good tube.
madmax
Gotcha, will do. I'll report back in a few...HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Put the old tube back in. No problems at all.
I suppose the new tube is the culprit. After consulting with one of our resident audio techies, he suggests the tube probably has a heat related issue since the problem occurs after the tube heats up for a while.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Did you clean the pins?
(see post numero two)Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
How do I clean them? I have some of that Caig stuff, but was reluctant to use it because I don't want to gum up my tube sockets. Not saying Caig does that, but didn't want to take any chances.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Caig will work fine, and won't do any harm to the socket. Just make sure everything is completely dry before power up.
Apply to a cotton swap or pipe cleaner and give it a whirl.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
FWIW the pipe cleaners Russ suggested do an excellent job with the Caig.
RT1 -
OK, I cleaned the pins with Caig and a q-tip, and popped the tube back in. No issues for 1.5 hours. Gonna do some more testing over the weekend and will report back...HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Congrat on the find. It must have drove you crazy. Good music should help the pain.engtaz
Yeah, I think the tube is bad.
I ran my system this morning and it went for over an hour, then the same problem occurred. I had the top panel off and I noticed the fire in the tube was not burning. Somehow it must have cut itself off. It's gotta be some sort of heat issue with the tube itself because my CDP doesn't get hot. This phenomenon has never occurred with a my previous tubes.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Before you clean tube sockets make sure B+ has drained out of the capacitors. It could be very enLIGHTNING if it hasn't.
I know you already did it and I didn't think about it in time, sorry. Next time you will think of it...
You best give that tube a dirt nap,it sounds like it is NFG.
btw.what did the filament look like before it stopped working?was it brighter than normal?Testing
Testing
Testing -
I dunno. I didn't see it right before the CDP lost volume.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
I had that happen before. It was an expensive, sweet-sounding Tung-Sol round plate 6sn7 :mad: About 30 minutes into a listen, the right channel just peacefully faded out and didn't come back. Visually, I noticed one of the two triodes wasn't lit up anymore. I didn't try using it after that - I figure once a tube shows signs that it's bad, the safest route is to keep it away from expensive gear.Tannoy Dimension TD10, SOTA Star Sapphire, Heathkit W4A's, McIntosh MC2100, Eddie-Current Zana Deux, Singlepower SDS, Sennheiser HD650, Audio-Technica L3000, Sony Qualia 010
I revived this old thread because I have some new info about this problem of my CDP petering out after extended play of maybe 1.5 - 2 hours. I still have this problem, but it's not really a big issue because I rarely play music that long. I noticed this problem back in May 2007 after changing out the tube to a Bendix 6385.
Anyway, today I hooked up a brand new amp and the problem has occurred twice already after 30 - 45 minutes of play, so I'm thinking the amp is somehow playing role in this issue. Both the CDP and amp don't appear to be getting too hot.
Can tubes be picky about amps?
Is it a DC voltage leak?
Will I damage my CDP, tube, or amp by continuing to play music?
Thanks.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
You swapped the tube, problem went away, no?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Same tube, different amp, bigger problem.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Yeah, but reading earlier in the post, you swapped tubes, and the problem went away. If so, that pretty much sums it up, right?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Why did you put a possible bad tube in another piece of gear? Am I not reading something correctly?CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Yeah, but the Bendix tube stays because it sounds so good. My question is more about why it's happening more frequently with a change in amp.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
More power trying to go through a bad tube ? ?
The cdp doesn`t put as much through it as the amp ?Cary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
Or maybe the tube is just going south....faster????? You know tubes can do weird things....I would remove it no matter how good it sounds. Maybe it's time to try the Sylvania gold pins...._________________________________________________
Maybe its time to get a cheap tube tester.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Or find another Bendix tube, if you are dead set on it.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Good ideas. Thanks, fellas.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
