Memphis 12"
Dcezy
This is my Amp
*****Mtx thunder 600xd ::325 rms x 1channel at 4ohms( 600watts rms x 1channel at 2ohms) variable low-pass filter(40-200 Hz at 24 dB per octave)
bass boost (0-12 dB at 40 Hz ).
1200 watts peak power::
I just got 2 Memphis 12" 250 watts RMS 500 watt peak power 88db
They arent hittin like they should. Im not geting the bass out of them like i thought i would.
My Question is do i need a new amp or better subs to get the bass im looking for. Thanks
Post edited by Dcezy on
Are you certain that both woofers are wired with the correct polarity so that they are operating in phase?
btw you might try asking in the car audio section this is the home audio subwoofer area.Testing
Testing
Testing -
ok, sorry. il post it there
