downfiring drivers vs. sidefiring drivers
ronaldo141
does anyone know the benefits of downfiring drivers vs. sidefiring drivers if there are any and which is the best to have? thanks.
Post edited by ronaldo141 on
i think the differance is between them is if you do a down flirting sub and you can put a plate to help out sertan frencies. but if you have a carpeted room you will lose some bass. also the sub has to have to be able to be down flirting it has to have a small % of vc sag. if it has to much you will dammage the woofer over time. but i have allways had front flerting subs. or back in the case of my car lol
WhaDsay?More later,
Tour...
Vox Copuli
Flirting subs??
My PSW1200 has a downfiring port and side firing speakers. The port fires into its own base. Power port tech.
In my livingroom setup I have a AR 12" that is downfiring and once again it is firing down on a wooden base that is part of the sub itself. It has about a 2.5 inch gap and the port is also downfiring. For a about $300 it has done nothing but impress me from day one.
A miss perseption perhaps with down firing subs is that the subwoofers fire directly into the floor. Whatever surface you put it on. In most cases would be carpet. (not good) I have only seen very cheap subs built like this - like a ratshack special for example.
Inwhich I owned in one of my first setups and it sounded aweful. -
Have u thought of putting them on a raised platform? My mom has a altec lansing computer sub, downfiring. It use to be my friend's and his was on carpet and it sucked eggs. I traded my computer speakers off with him and gave them to my mom. It is now on a platform on the desk and I swear it rocks the house. night and dayDamn you all, damn you all to hell.......
I promised myself
Damn you all! - ATC -
Ok, so my Infinity BU2 is downfiring on carpet w/o a platform. Are you guys saying that I should raise it off the carpet and have it downfire on a hard surface, or raise it but still have it downfire on the carpet? If so, any suggestions for what might be most effective?
Doc?
ThanksMains: polkaudio RTi70's (bi-wired)
Center: polkaudio CSi40 (bi-wired)
Surrounds: polkaudio FXi30's
Rear Center: polkaudio CSi30
Sub: SVS 20-39 PC+
Receiver: ONKYO TX-SR600
Display: JVC HD-56G786
DVD Player: SONY DVP-CX985V
DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
Remote: Logitech Harmony H688 -
Well obviously if you put it on a hard surface...right below the sub - there will be no difference. Put some feet on the sub and put it on a surface...but try it first to see if u find ne results...Damn you all, damn you all to hell.......
I promised myself
just get a large piece of slate put it under the sub this will help you out.
I can kick in a bit with some confidence here (I passed a test inside joke).Originally posted by MxStYlEpOlKmAn
My mom has a altec lansing computer sub, downfiring. It use to be my friend's and his was on carpet and it sucked eggs. I traded my computer speakers off with him and gave them to my mom. It is now on a platform on the desk and I swear it rocks the house. night and dayOriginally posted by kberg
Ronaldo,
As for down vs. front? It's just the first design decision. Equal performers can be found using both designs. With true bass dispersion is not an issue so you dont need the spread often touted for downfires. Absorption not an issue so you dont need the direct-line touted by frontfires. Once your ears and gut are satisfied, it can come down to cost-value and eye appeal. For some that means front because they want to see that driver working (it can be appealing).More later,
Tour...
Vox Copuli
thanks for your help tour2ma. I've also seen some interesting older velodyne subs with both down and sidefiring drivers, but evidently it doesn't make a big difference.
Originally posted by Tour2ma
First kberg, at what frequency is your crossover set? If its over 120Hz bad, 120Hz good, 90Hz better. Somewhere in the 90 to 120 range, where true, deep bass starts, fear of a subs output being muffled by carpet ceases to be a real issue for a down firing. True, deep bass is difficult to get rid of, that's why it's the principle realm of the standing wave. A number of company's make a pretty good living at offering solutions to standing wave issue (tube trap for one) because carpet, drapes, etc., just dont phase true bass.
My crossover is set at 80Hz, so it seems like I'm Ok on that issue.Mains: polkaudio RTi70's (bi-wired)
Sub: SVS 20-39 PC+
Tour, So your saying putting Bose 'Bass Modules' on a raised platform will help the bass? Considering they play about 25% or more of the Bose Cube's Midrange...hahaDamn you all, damn you all to hell.......
I promised myself
kberg,
At 80 Hz you should be fine from a loss consideration, but another problem that Doc alerted me to, could become a factor. Depending on the bass attenuation rate of your processor you could face wave convergence due to multiple bass sources. Even with a 12 db per octave roll-off, your mains are still reproducing a fair amount of bass information for a ways below 80 Hz. Ditto for your sub above 80.
Multiple bass sources can interact directly with each other as well as all of their reflections, creating bass hot (reinforcement) and cold (cancellation) spots in you listening room. If you play test signals under 100Hz at 80 db or less, a walk around your room, with or without a SPL meter, should let you know whether this is occurring. If it is, raise your crossover point to 90 and repeat.
Sid,
Hadnt looked at bose in awhile, but seem to remember theyre front ported, so theyre not firing into the carpet at least. Cant say if raising will help for sure, but if they firing into a sofa or chair, yes itll help prevent the killing of the frequencies over 120 Hz they handle. And as with any speaker that reproduces bass, corners will reinforce bass, away from walls will lean it out.
I tried to help a friend a while back that went bose. Corner reinforced the base, but they just sounded so boomie, any benefit of sounding deeper was lost.More later,
Tour...
Vox Copuli
kberg,
You mean set the crossover at the sub at 90Hz, if needed, yes? When I said I had my crossover set to 80Hz, I meant at the receiver. Currently, the setting at my sub is all the way clockwise to 200Hz, per Doc's recommendation to prevent double filtering. So, with that said, what recommendation(s) do you have?Mains: polkaudio RTi70's (bi-wired)
Sub: SVS 20-39 PC+
Would doing this yield a tighter bass response from my sub? Is that the idea?Mains: polkaudio RTi70's (bi-wired)
Sub: SVS 20-39 PC+
kberg,
Only recommendation I was making was to check your room to see if you have a problem. If youve been living a while with your rig set as you described, its not likely that you do. But if you listen in the same spot all the time, its possible that the bass in other listening positions in the room is unnatural. It doesnt hurt to check.
Should you find an issue, any crossover changes would be at the AVR, not at the sub. The sub should stay at the max setting you described to eliminate the double filtering Doc cautioned you against.
All the above is based on communication with Doc. I was keen to crossover to a planned sub at 50 Hz and he just warned me about possible problem of leaving that much bass in my mains. But he said try it and see. Just trying to pass the learning on.
As for the slate? Can always try it I guess, but before I spent money on slate, Id try:
- moving the sub around to find the best response spot for the room, and
- find some scrap particle board, thick plywood or other dense media thats big enough in the garage to get a feel for the change.
Then again maybe slate is cheap, but I know its very heavyMore later,
Tour...
Vox Copuli
Tour,
Understood. Thanks for your responses!Mains: polkaudio RTi70's (bi-wired)
Sub: SVS 20-39 PC+
Your Welcome..
BTW, Love the quote...More later,
Tour...
Vox Copuli
