3 gnx 12's
saranaz
saranaz Posts: 4
edited March 2003 in Car Subwoofer Talk
watup guys.....yea i just bought 3 gnx12's the 4ohms....they were cheap as hell.....anyways....i need sum ideas on what amp or amps to get
Saranaz
Post edited by saranaz on
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited February 2003
    well you wire them in parallel and you get 1.33 ohms.
    so... what's stable at 1.33 ohms and will give you (175 x 3 =) 525 watts ??
    the only one that comes to mind that will put out that power at 1 ohm (will actually do it at 2 and 1.. same power, stable at both)... is the JBL BP 600.1 ... i also suggest it because it is cheap as hell as well (since u mentioned u got the subs cheap i figure goin on the cheap is a good thing).
    BP 600.1 does 600 watts x 1 into 1 ohm or 2 ohms... 300 x 1 into 4 ohms... cost you like 175 on ebay new in box... prolly 10 bucks to ship it.
    mtx 6500D will do like 600 - 650 x 1 into 2 ohms.. and it will remain stable down to 1.3 ohms same as the 81000d, but it's going to cost like 275 ebay / 500 retail and for the applicatioin i dont think it would be as good as the JBL.
    The Artist formerly known as PoweredByDodge
  • Systems
    Systems Posts: 14,872
    edited March 2003
    Saranaz
    hey man where did you pick up your subs? i plan on doing the same setup as you
    Testing
    Testing
    Testing
