DIY SDAs
zingo
I am looking at building a pair of SDAs. I know that it has been done before, but can't seem to find any of the posts. Using the schematics that were posted earlier, I have been mulling over my options. I am not sure which model I might build, but the cross-overs seem pretty easy to build. Even though the schematics have the components, does any one know the exact specs on the capacitors or resistors, or some where that all the parts can be commondered?
Post edited by zingo on
Ben built some recently, here is the thread:
http://www.polkaudio.com/forums/showthread.php?t=53273
He seemed to have done a lot of research, and would be a good resource. He also likes to help DIYers. He hasn't posted in the last couple weeks, so he may be on vacation or something, but if he is around he will probably respond in this thread soon.
Good Luck!"Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason." -
Why not just buy a pair, you know, some of the ones that were actually engineered to sound 'right'? Plenty on the used market to choose from.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
This is your best option as you'll find aquiring the correct cabinet material, parts, drivers (especially if new), etc. it's going to cost more than a very good used pair. Of course if you enjoy the actual building and assesmbly.......
There is much more to buildong them than soldering, cutting and gluing. I was just reading the Compenduim and the drivers are mounted in a certain way in the baffle to get certain advantages. The angle and spacing is extremely critical ot get the best SDA performance. What those spec's are, I have no idea. Not a simple task to be sure.
Ben did build his after months of research and calls to Ken at Polk."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul!
