DS-2 won't work
galeforce13
galeforce13 Posts: 1
edited February 2003 in Electronics
I bought this polk audio theater system from Sam's Club for $250. It was a display. The sub and one of the small speakers do not work. Should I return it or is there anywhere I could have it repaired?
Post edited by galeforce13 on
  • brettw22
    brettw22 Posts: 7,621
    If you like the sound out of the system overall, then just take it to a repair shop. You should have a 5 year warranty, even if the item that you bought was a display. I remember a thread a while ago about Sam's carrying those HTIB systems, but i don't know if anyone ever touched on them being officially authorized as a typical retailer. As long as Sam's is an auth'd retailer, you should be fine. If they're not, according to Polk, then I'd say return it and upgrade. I think that you'd have to call Sam's to see what they say about where to have the items repaired through, but since they're a warehouse retailer, I'm gonna bet that they tell yo to take it up with Polk......
