advice on buying a lcd tv
sageleo
sageleo Posts: 170
edited September 2007 in Electronics
I'm looking to buy a 42" Lcd hdtv just wondering what u think is the best out there.
T.V.- Sony KDL50W800B
Blu Ray- Custom built HT PC
Vizio Sound bar- S4221W
Post edited by sageleo on
  • janmike
    janmike Posts: 6,146
    If I was looking to buy a LCD it would be a Sony, but that's me.
    Here is a link that may help. Good luck.
    Consumersearch
    Michael ;)
    NORTH of 60°
  • ViperZ
    ViperZ Posts: 2,046
    I'd go with Sony LCD too. 2nd and 3rd would be Sharp and Samsung.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • MKZ
    MKZ Posts: 1,068
    sageleo wrote: »
    I think you have to go either 40" or 46" in LCD.
    SONY XBR series is the best. Samsungs are better than other Sony series.
    SONY KDL-46XBR5, KDL-40XBR4, Samsung LNT4065F or LNT4665F for 1080p resolution and
    Samsung LNT4042H, LNT4642H, LNT4053H or LNT4653H for 1080i/720p resolution are great. I had spent a month research online and window shopping at bestbuy, circuitcity and J&R. I went with Samsung and I am happy with it for the price. I didn't want to pay Sony for twice the price of Samsung.
    Check Fry's or Amazon for better deals.
  • krabby5
    krabby5 Posts: 923
    I would say Sony as well...I have a 46" and it's not even an XBR or 1080p..and i love it..
    Pioneer Elite VSX-53, Polk RT800i fronts, Polk CS400i center, FX500i surround, Velodyne sub
  • sageleo
    sageleo Posts: 170
    Thanks for the input, I decided to go with a Toshiba Regza 42" 1080p, with 3 hdmi inputs.
  • rskarvan
    rskarvan Posts: 2,374
    I would go plasma.
  • janmike
    I did and really like it. Panasonic 50". To each his own.
    Michael ;)
    NORTH of 60°
  • BaggedLancer
    BaggedLancer Posts: 6,371
    I have a 40" Samsung 1080p LCD and a friend has the Sony 40" 1080p. In my opinion there is definately a difference in PQ between the two sets with favor toward the samsung. Playing xbox 360 also seems to be better on the Samsung.
    Only thing I don't like about the new models of samsung is that they switched to a glossy screen, so in improper lighting conditions you may see reflections.
    My other friend has a 42" Sharp Aquos 1080p and that is an absolutely stunning TV for the price and gives my Sammy a run for its money. If I were you I'd get the Sharp, since you get 2 more inches(42 v. 40) and the quality is outstanding.
  • impronto
    impronto Posts: 25
    sharps are pretty good, they also have a one dead/stuck pixel policy
  • cyberhazard
    cyberhazard Posts: 67
    I have a Sony KDL-46XBR3. IMHO nothing comes close. Not in LCD or Plasma. But, they are spendy. You can get other brands the same size for a lot less money.
    The Escape Pod Equipment
    Samsung HL-S5679W
    Sony STR-DA5200ES
    Outlaw 7125
    Sony 60GB PS3, Blu-ray Disc
    TiVo Series 3 HD
    Universal Remote Control MX-900
    Polk Audio LSi9 ebony, fronts
    Polk Audio LSiC, center
    Polk Audio LC65i in wall, surrounds
    SVS PB12-Plus Piano Black
    Outlaw PCA interconnects
    BetterCables for HDMI & SUB
    Master Bedroom
    Sony KDL-46XBR4
    Sony 40GB PS3, 2nd Blu-Ray Disc
    Polk Audio i-Sonic
  • gyver65
    gyver65 Posts: 13
    Have you considered a DLP rear projection TV? You can get a much larger screen for a much lower price. I am considering purchasing a 57" Mitsubishi 1080P DLP for less than $1500.
  • AndyGwis
    AndyGwis Posts: 3,655
    If you're looking budget, I have two Westinghouse LCDs and am very happy with the performance per dollar for each.
    You can probably get a 1080p 42" Westinghouse for a grand less than the big names. Their picture quality might be slightly less, but not noticeably, and haven't had any issues with either.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • JimBRICK
    JimBRICK Posts: 1,543
    IMO if you want the best get an xbr if you have a budget the TOshiba and LG models look real good this year
    2 CHANNEL
    Speaker - Klipsch Heresy II
    Under construction
  • dipiazza
    dipiazza Posts: 363
    I have to say i have the 32 inch version of this...
    http://www.vizio.com/products/detail.aspx?pid=30
    price to performance you really cant beat it. heres the 1080p version:
    http://www.vizio.com/products/detail.aspx?pid=31
    Terps Swimming!
    HT Setup
    TV: Vizio VX32L
    Reciever: Pioneer VSX-D914
    HD-DVD Player: Toshiba HD-A2
    Fronts: Polk R50s
    Surounds: Polk R30s
    Center: Polk R20's
    Subwoofer: SVS 20-39PCi
    2CH Setup
    Integrated: Onix SP3 Tube
    CD Player: Sony CDP-CX355
    Speakers: Onix Strata Mini in PR Finish
    Signal Cable: Classic Speaker, Analog 1 IC
    Headphones
    Grado SR 60, Bang & Olufsen A8, Shure e3
    Other Stuff in Use
    Onix xls, Dual Onix x-subs, Onix Ref .5, Dahlquist M903, Teac A-1D, Marantz 1060
  • icehouse1
    icehouse1 Posts: 37
  • Willow
    Willow Posts: 11,215
    You can save some cash by not buying 1080p as depending on the size, you will not notice the difference and to add to that HD tv is in 720p.
  • krabby5
    krabby5 Posts: 923
    Willow wrote: »
    You can save some cash buy not buying 1080p as depending on the size, you will not notice the difference and to add to that HD tv is in 720p.
    That's what I did...and i usually always buy more than I need..but I couldn't justify the extra cost..maybe if I used my tv as a computer monitor..but that was earlier in the year. It may be harder to find 720p LCD's now...I think all the newer ones are gonna be 1080p...plus the sets with the best features and quality will all be 1080p now..
  • margate21
    margate21 Posts: 105
    sageleo wrote: »
    umm....he bought one already. fyi.
    lsi 15's, lsi c, lsi f/x
    onkyo 805
    sunfire tga 5200
    toshiba - xa2
    panasonic bd30
    sony kdl40v2500
    svs sb12+
  • thejck
    thejck Posts: 849
    go with a vizio I have one and like it the 47 one
    check out avsforums for a lot more information on it. i did a lot of research there and read throuh like 70 plus pages before i bought the vizio. i like it as I am not too picky and i could not afford the top of the line one
