interconnects
  • Tred
    Tred Posts: 9
    edited September 2007
    Yes. I have two pairs of MIT Terminator-2 from 15 years ago for a little more than $100 per pair.
    MIT sells $200.00 IC's???
  • Tred
    Tred Posts: 9
    Not sure. Check with your customs.
    There are U.S. based web retailers carry these lines of products. Do a Google search.
    Face wrote: »
    If I'm purchasing from CA, are there any tariffs, etc..?
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    MIT Shotgun is my personal favorite they smoke the others I have tried/used and abused.
    RT1
    F1nut Posts: 51,781
    I see. Have you tried the current Shotgun S1's?
  • Tred
    Tred Posts: 9
    Nay. I'm not a cable guru by any stretch. I've always used cables in the reasonable price/performance range. The old Terminator-2 was a starter model back when I bought it. Yeah, I know you're about to tell me what I've been missing. There is no doubt that the Shotgun should be magnitude better. This much I know though - those old pairs of Terminator-2 blew away pairs of Linn and Naim "stock" interconnects priced in the same $100 range. I've built a pair of Oyaide PA-02 terminated with copper Bullet Plugs and they're no doubt better than the old Terminator-2.
  • hearingimpared
    hearingimpared Posts: 21,136
    Face wrote: »
    Only if you're a Republican. . .
    . . . oh you meant CA = Canada!!!:eek:
    SCompRacer Posts: 9,112
    Harmonic Technology Pro Silway MK III Plus's smoked MIT S1's in my system. One size does not always fit all.
    F1nut Posts: 51,781
    So true Rich, I couldn't get the Pro Silway's out of here fast enough.
  • madmax
    madmax Posts: 12,434
    Tred wrote: »
    You would probably like the MIT S3's then. Lots of performance for the price.
    madmax
    Vinyl, the final frontier...
  • hearingimpared
    I'm using orange colored coat hangers!!!:D
    I felt the same away about the S1 IC’s and S3 speaker cables. I am truly sorry if I gave the impression that HT’s are the final solution for everyone, like MIT’s are supposed to be.
    F1nut Posts: 51,781
    No biggie, not everyone's final solution is another's.
  • reeltrouble1
    OK, how about some Nordost Valhalla then? I was really jonesin for the Heimdall for a bit as well.
    Then I thought about how great my MIT cables had made the rig sound and the jones subsided, man that was a close one that day.
    The fact is many members here do use the MIT Shotgun and have had great success with them, for some they are just too pricey and for others, well, hey what works for you you certainly should use.
    When I say my MIT smoked my prior cabling, well, the cables I was using were just not even close to being in the same league as the Shotgun's, so the result was hoped for and even expected.
    RT1
    I have heard all the way up to the older Nordost SPM’s, but kept what I have. Most of you know my friend Normanality. He went on a quest and tried just about every IC in existence. Cardas, Nordost, etc. You guys know that movie, Snakes On A Plane? Norm is responsible for providing the idea for that movie.
    You see, Norms audio dealer buddy took a big time job in Hollywood. He came to visit Norm and brought a producer with him. No matter where you looked, stepped or wanted to sit, there were IC’s all over the room. On the plane ride back, a movie was born.
    OK, so part of that story is BS, but there were IC’s all over that room, and he was kind enough to allow me to experience them.
    I must add that I had a good experience with the MIT’s and the Carver Amazings. Once I went with ESL speakers, the magic was gone. I can understand the possibility of capacitance with the network box on the speaker cable and ESL panels (to an amplifier or speaker cable, ESL panels appear as a capacitor). Roger Sanders even addressed that with a speaker cable designed for ESL panels. I always felt you got the full bang using MIT cables from IC to speaker, but couldn’t figure out why the IC’s by themselves didn’t work out. They seemed to veil the sound. It was a costly audio lesson for me, but the good side was a CP member got them.
  • hearingimpared
    I would have no objections to you, Jesse and Ted sending me your MITs and Harmonic Technology Pro Silway MK III Plus's to me to try out in my rig. It is a smoke free environment and the dog and 10 year old are not permitted in the audio room.
    F1nut Posts: 51,781
    I no longer own the HT's, but you might talk me into bringing a rig full of MIT's for the day.
  • hearingimpared
    I'm talking, I'm talking, if I say it any louder you will here it all the way across Maryland!!!:D
    F1nut Posts: 51,781
    Yeah ok, we'll figure something out.
  • BottomFeeder
    BottomFeeder Posts: 1,684
    Have you ever noticed how people's descriptions of audio equipment sounds a bit like descriptions of wine?
    :D
    "Wish I didn't know now what I didn't know then." Bob Seger
  • hearingimpared
    :D
    Audiophiles started using those descriptions first:D , the wine drinkers just copied it!:D ;)
