SDA tweeter wiring, and more
danger boy
ok. until the SDA compendium gets here from Dark i am stumped.
i am replacing the SL2000 tweeters in a pair of SDA 2B's with the RD0's cool right?
on the left SDA 2B on the SL2000 when I removed it.. the white wire was going to POS and black wire to NEG
on the right SDA 2B it's just the opposite.. black wire goes to POS and white wire to NEG
should they be like that? or which one is wired correctly?
another weird thing.. the left stereo driver was dead.. so i pulled it out. it's labled MW6503 ? the manual I have for the 2B's says the stereo driver should be MW6510
So I pulled out a MW6510 from my 2A's and put in the 2B's like it's suppose to have.. sounds good again.
Maybe someone at one time replaced the stereo mid bass driver with the wrong one.
PolkFest 2012, who's going>?
Post edited by danger boy on
on the right SDA 2B it's just the opposite.. black wire goes to POS and white wire to NEG should they be like that? or which one is wired correctly?
Both should be wired as above. You can easily check for proper wiring by looking at the crossover. At the connector on the board, you'll see + and - markings, black should be + and white should be -.
Do you have the right manual, the stereo drivers should be 6503's, the dimensional drivers should be 6511's.Political Correctness'.........defined
President of Club Polk -
yup Jesse, I have the manual for the 2A and the addendum to the instruction manual which covers the 2B, 1C and SRS-2A
the addendum lists the stereo driver as MW6510 and the dimensional one as MW6511 for the 2B's
no where in the lit does is say anything about MW6503PolkFest 2012, who's going>?
I believe my 2B's have 6510 for the stereo drivers also and 6511 for dimensional drivers.
ScottI like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D -
The schematics say 6503's and 6511's for all versions of the 2B's. My 2B's have 6503's and considering that yours came with the same, I'd say it's a safe bet that it's the right driver.
As far as the addendum, I'd have to question it as the SDA 2A's use 6510's in both, the 1C's use the 6510 as the dimensional and the 6511 as the stereo, which is opposite of what your addendum states.Political Correctness'.........defined
agreed... i need to replace the 6503 with another of the same.... 6503's are tougher to come by than 6510's.
Here is an auction for 4 of them if you need that many.Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
As far as the addendum, I'd have to question it as the SDA 2A's use 6510's in both, the 1C's use the 6510 as the dimensional and the 6511 as the stereo.
I just pulled the drivers. I stand corrected. I will now sit in the corner.
6503 for stereo driver and 6511 for dimensional driver. Dated December 1988.I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D -
yeah, i'm watching those very closely..
maybe if a Polkie from here gets them. i could buy one off of them
Polk has 6503's.Political Correctness'.........defined
The SRS 2 PDF File posted crossover shows 6510 for dimensional, and 6511 for stereo.
Where are we coming up with 6503's ? -
F1, are you referring to the SRS 2's or the SDA 2's ?Both should be wired as above. You can easily check for proper wiring by looking at the crossover. At the connector on the board, you'll see + and - markings, black should be + and white should be -.
SRS 2's are 6510 dimensional and 6511 stereo, at lest the later versions are, according to the posted schematics. -
They are talking about the SDA 2B's.Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner.
Thank you, Kip.Political Correctness'.........defined
SDA 2B to be exact
as I said before. it's just weird but not unheard of.. that my addendum says it should have a MW6510 but Jesse is right.. if they came with Mw6503's, then that's what I should use
anyone know what one costs new from Polk?PolkFest 2012, who's going>?
Probably a couple grand.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Wait, hell I have a couple here I'll let go for the low, low price of HALF of that! Richard? Who's your favorite Little Rascal? Alfalfa? Or is it........................Spanky?.................................Sinner. -
I hope you both get jock itch, real bad.
the MW6503 arrived today.. and it's now installed and being burned in with the SDA 2B's. it's stiffer than the old ones.. i assume it's because it's new and the rubber is still very tight. looks nice too.PolkFest 2012, who's going>?
