recommendations for HT receiver
bikezappa
I'm in the market for a new HT receiver because of all the changes in video processing. Right now to change from TVHD to DVD I must change the projector input and the audio input. Also if I use my S-VHS or laserdisc I must also change both inputs. I really want a receiver that can up convert everything to a HDMI signal. I want to be able to switch any audio/video singnal with the receievr's remote.
I looked at the Pioneer VSX-82TXS but was concerned that the HDMI cable was compatable with all units. Not sure what that means because I thought HDMI cables were universal. I would also like to use and try the MCACC speaker EQ correction system. I was also concerned with the complexity of set up.
I can spend between $1000 to $2000 for a new unit.
Any advice on receivers would be appreciated.
Post edited by bikezappa on
Also, I have given up on any Sony receiver because of the set up complexity.
Burn me once Sony and I will never forget it, even 10 years later. -
this is my bid for best receiver...........
http://nadelectronics.com/products/av-receivers/T785-A/V-Surround-Sound-Receiver/images
Power output (stereo, 8 ohms within rated distortion 2 x 150W (21.8dbW)
IHF dynamic power 8 ohms 2 x 250W (23.9dBW)
4 ohms 2 x 350W (25.4dBW)
2 ohms 2 x 450W (26.5dBW)
Simultaneous power output surround mode 7 x 120W (20.8dBW) - [7 x 190W(22.8dbW)Minimum Continuous Power (FTC)]
Total Harmonic Distortion at rated power 0.05%
IM Distortion at rated power 0.05%
Damping factor 8 ohms 60
Sensitivity and impedance (R and C) 400mV / 50k Ohms
Frequency response 5Hz-20kHz 10 to 20,000 Hz ±0.3dB
Signal to noise ratio rated power 8 ohms >90dB
1W/8ohms >80dB2 CHANNEL
Speaker - Klipsch Heresy II
Under construction -
Jim
More than $2000 but looks nice.
What is different bewteen HDMI 1.1, 1.2 , 1.3?
My front projector is 3 years old. Is this a factor for upconverting with a receiver? -
heres a good article about hdmi
http://www.engadgethd.com/2006/10/13/ask-engadget-hd-is-it-worth-the-wait-for-hdmi-1-3/
and a place for other good receivers
http://www.soundpros.net/Scripts/prodList.asp?idCategory=42
the t763 would rock your world
2 CHANNEL
You should look at the new Denon receivers or even Onkyo.58" Samsung Plasma (on wall)(calibrated)
LSi15's front (modded xo's)
LSic center
LSiFX's sides
LSi7's rears
Sunfire Sig. 600 amp for 15's
Sunfire Sig. Cinema for C,S&R
Sony ES 3000 pre/pro
SVS 2039 PC Plus sub 12.3 (16hz tune)
PS3
Wii
Signal and Audioquest ic's
12 awg monster speaker-cable (bi-wired)
Belkin PF60 power conditioner
Monster power conditioner for sub -
2k should give you a fairly nice window...
I here the NAD is a great unit also..
I wish I would have got the one Mark had for sale back whenCary SLP-98L F1 DC Pre Amp (Jag Blue)
Parasound HCA-3500
Cary Audio V12 amp (Jag Red)
Jolida JD-100 CDP
SVS PC-Ultra Sub
MIT Shotgun S1 I/C`s
AQ Black Thunder Sub Cables
PS Audio Plus Power Cords
:cool: -
If you want "new new" Yamaha just released new $1200 and $1600, Denon has got some new stuff on the way if it isn't in the stores yet, or Pioneer Elite. If you want a deal, Denons will be a bit harder to find since they have been in a tight inventory spot for a couple of months, but Yamaha didn't...you could probably score a good deal on a 2700 if you aren't hooked on the HD surround issue.
Arcam has the AVR280 in your price range (great sounding stuff, I have an AVR300), NAD has been mentioned. I'm not a Rotel guy at all, so I'm not going there. Sonically inferior to the Japanese stuff above, and $500-1000 more. I've done the head to head, and it wasn't pretty, the dealer just about **** his pants.
That should be enough choices for anyone.System:
VPI Scout/Benz Ace
Sutherland PH2000
Arcam CD72
Yamaha DVD-CX1 (primarily for CD..26 lbs, all BB D/A)
Audioprism Mantissa w/Reference PS
Parasound HCA750 (temporary)
Audiovector M1 Signatures
Kimber 4TC x 2 -
1.3 is the latest HDMI standard (we think). The Pioneer is not difficult to deploy. Listen to whatever you're going to get BEFORE you purchase unless you can return it without issue. Check out the way each sounds with your speakers in your room. Have fun, we've got the 84 and are extremely pleased. We use it as a pre/pro (as our LSI's are completely powered by external amps hanging off the 84) and the MCACC system is a nice touch. The 84 has 4 HDMI in's (fully configurable) and 1 HDMI out which goes to one of the 2 HDMI in's on our Plasma (the only HDMI cables we've had any luck with are the Blue Jean BJC Series-1 Belden Bonded-Pair HDMI). Just be sure to Listen to all the AVR's you're considering. Good luck, enjoy, and please keep us posted!!Home Theater
Chane A3rx-c's, A2rc-c, A1rx-c's|Miller & Kreisel V-125's|Sony XBR65X810C 65" 4K LED TV|
Earthquake Cinenova Grande-5|Pioneer Elite - VSX-84TXSi-AVR|TRIPPLITE LCR2400|
Ultrasonic Amp Stand|Blue Jeans,Audioquest,Monster Cables|
2 - Channel
Polk RTA 12c's w/RDO194 TWEETS, clarity ESA caps mills resistors (full mod)|Turntable|
Anthem MCA 2|Acurus Act 3 Pre Pro|Parasound P/Ph 100|Pioneer Elite N-30|Adcom GDA600|
Premier Rack|Blue Jeans,Audioquest,Monster Cables| -
http://us.marantz.com/Products/1875.asp#
this Marantz receiver looks like a really nice unit.. lots of features... people don't often think of Marantz when thinking of receivers anymore for some reason.. but I think their's look pretty awesome.PolkFest 2012, who's going>?
danger boy wrote: »http://us.marantz.com/Products/1875.asp#
I've been eying the Marantz myself. Anyone have an opinion of them? Are they warm, nuetral, bright, etc? Here is a link to an authorized dealer of new and b-stock -
http://www.accessories4less.com/cgi-bin/category/AVReceiver -
Funny how you should mention that:
http://www.hometheatermag.com/receivers/907sony3300/
As a former Sony AVR owner myself, I was surprised by this one.
