line driver voltage question..
ilikesound
if im using an EQ with built-in line driver, should i switch my voltage on my c400.4 to "high" level input? the eq says is outputs 7 volts, and the manual for the c400.4 says if it is anything greater than a 4v load, switch it to high input.
At Home:
Panasonic 42'' TC-L42U12 LCD
Pioneer VSX-80TXV
Toshiba HD-XA2
Sony PS3 - psn "metalguitars"
Xbox 360 - gamertag "giggidygiggidy"
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Martin Logan Dynamo (x2)
Audioquest interconnects and wires.
Away From Home:
JVC HDR-50
stock system in new car for now:(
Pioneer VSX-80TXV
Toshiba HD-XA2
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Away From Home:
JVC HDR-50
Post edited by ilikesound on
I think you answered your own question.
Yes.
