Man if it wasn't for bad luck I wouldn't have any Luck!
  • shadowofnight
    shadowofnight Posts: 2,735
    edited September 2007
    No correcting needed...I was as curious as you :) I just hope Shannon gets his replacement fast....but then in the gaming section he said his Plasma screen petered out too ? Hope it all gets back soon !
    The first rule of Fight Club is you don't talk about Fight Club
  • SKsolutions
    SKsolutions Posts: 1,820
    Most of the damage is around the output transistors and the diodes above it. You should really check your speaks to make sure there is no damage. A guess would be diode and thermistor, then output transistor(s). Not good.
    I'd ask them to send me the channel, and keep the amp at home. . . in the smoking section of course:D
    -Ignorance is strength -
  • Shannon W.
    Shannon W. Posts: 568
    the speakers did make a slight pop when all this happened. If they are f'ed up I wonder if sunfire would be responsible? I doubt it but it would be worth a try. It was there amp that sent the signal to the speakers. But oh well. if they are fried the that gives me the need to UP GRADE. looks like B&W or Paradigm next time.
    Shannon
    50" Samsung Plasma
    Sony STR-DA4ES "use as Pre/amp"
    Pioneer Elite DV-45A DVD Player
    DLO HomeDock Deluxe iPod docking station
    Directv HR20 Sat. Receiver in black
    Sunfire Cinema Grand 7 Signature Amp
    Monster Cable AVS2000
    Monster Cable HTPS 5100 MKII
    Polk LSi 9's Front R/L
    Polk LSiC Center
    Polk LSiFX R/L Surround
    Polk LSi 7's Rear R/L
    SVS PB12-Plus/2
    Velodyne SMS-1
    Sony PS3
    Click Here To View my Rig
  • Spacedeckman
    Spacedeckman Posts: 96
    Lost a multisection high voltage cap on a Stereo 70 years ago. A strange whistling sound and a lot of smoke.
    Mark
    System:
    VPI Scout/Benz Ace
    Sutherland PH2000
    Arcam CD72
    Yamaha DVD-CX1 (primarily for CD..26 lbs, all BB D/A)
    Audioprism Mantissa w/Reference PS
    Parasound HCA750 (temporary)
    Audiovector M1 Signatures
    Kimber 4TC x 2
  • SKsolutions
    Mark
    In 1937?
  • SKsolutions
    Shannon W. wrote: »
    Shannon
    My concern is that when there is a short near the output stage, it sometimes indicates DC current, and that is deadly to speaker voice coils and some crossovers. You can do a basic test with a 9V battery to see if the coils are fried or not, positive to positive should push the cone out, reverse should push in. Maybe borrow an AVR from someone to check it out. Hopefully, it was so quick, there is no damage.
  • Shannon W.
    edited October 2007
    I'm still hooking everything up.. But here is what it took to fix this thing..
    they replaced all the amplifier PC boards,Blown Mosfet on the downconverter pc board, They updated the amp to current spec. Burned-in the amp for 3days and repeated all test to make sure everything was A.O.K. LoL
    Parts list went like this..
    1 Single Channel amp PC board
    3 Dual Channel amp PC boards
    1 IRF 640 Power Mosfet
    6 15k ohm 2v resistors
    1 12k ohm SMC? (I can't read there writing.) Resistor.
    Shannon
    50" Samsung Plasma
    Polk LSiC Center
    SVS PB12-Plus/2
    Velodyne SMS-1
    Sony PS3
  • lightman1
    lightman1 Posts: 10,796
    edited October 2007
    rskarvan wrote: »
    You aren't supposed to let the smoke out of electronic equipment. Amps always seem to work best when the smoke stays on the inside.
    Never..EVER let the smoke out of anything electrical....bad ju-ju.
  • Shannon W.
    edited October 2007
    OK, here is a update. I got everything hooked up and fired up the rig. I don't know what sunfire did to this amp but there is a whole new found luv for my system!!!!!!! I don't know if it is because i was lost with out it for so long, but all I can say is "WOW!!!!". I almost forgot what the SvS sounded like and those damned old LSi9!! Good thing is when I had my little pyro show it didn't kill the speakers.
    Well guys I had to let you know that I got off my lazy butt and finally hooked it all up..
    Good night to you all!
    Shannon
    50" Samsung Plasma
    Polk LSiC Center
    SVS PB12-Plus/2
    Velodyne SMS-1
    Sony PS3
  • Shannon W.
    edited October 2007
    Sorry guys but I have been listing for the last hour at louder then normal Volumes and all I can say is OMG!!!!!!!!!!! I don't know what I have done this whole time it was gone!
    Shannon
    50" Samsung Plasma
    Polk LSiC Center
    SVS PB12-Plus/2
    Velodyne SMS-1
    Sony PS3
