What Subwoofer should I buy?
stangjason
I currently have two (front) Polk R300, two (rear) Polk R150, one (center) Polk CSR and an old JVC 10" subwoofer. I'm looking to replace the subwoofer with something better and wanted your opinions on a good subwoofer to replace it with. I'd prefer to keep my budget less than $200 but can maybe wait till Christmas if I choose to go over that.
Oh and little info on the room. The TV is in the corner with about 14 foot between it and the center channel from the viewer with the subwoofer behind the TV. Also the den is part of an open floorplan with the kitchen and dining room behind it which has apparently made my subs lack of power a glaring weakness.
Thanks,
Jason
Thanks,
Jason
Pioneer vsx-1120k, B&K Sonata series video-5 amplifier, Polk Rti8, Fxi3, Csi5, and HSU VTF-1
Post edited by stangjason on
For $200 - all I can suggest is DIY.
You can build a box (or end caps for a sonotube) and purchase a nice 12"-15" sub (maybe $150??). Then for now, you can use the amp from your JVC to run it. (in a large enough box, you would not need a ton of power).
If DIY is not an option - I don't think your budget is high enough to justify the upgrade. (then again - I could be wrong, maybe you can find a good deal on a nice used sub)
Save a little more cash and get a Polk PSW505. I just picked one for $320, and I am really please so far with it. Nice little sub for those of us whose's wife won't let them get a SVS.
I also seen thw PSW404 for $269 this past weeked(no clue how it compares to the 505, but I bet its better than other subs in that price range) -
I started off aiming at the same budget, but ended up buying a BIC H-100 off of eBay for $239. It's great for the price... I don't think you'll find better. Do a search for that and you have to send the guy an offer of $200. Shipping will be $39 I believe.
Wait until Christmas and increae your budget. Don't waste your time and money on a sub-par sub.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Save your money until you can afford a worthwhile subwoofer.
The Bic H100 is an excellent budget sub. Not many have heard it here, but it competes quite well with retail subs like the Velo DPS10 & 12 or Klipsch Sub10 or 12 in the $4-500 retail pricepoint...sound quality and output. While saving for a $500 ID sub will get you twice the performance. It's a good first step and will match well with the Rs.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
**** is right, save for an HSU sub.58" Samsung Plasma (on wall)(calibrated)
LSi15's front (modded xo's)
LSic center
LSiFX's sides
LSi7's rears
Sunfire Sig. 600 amp for 15's
Sunfire Sig. Cinema for C,S&R
Sony ES 3000 pre/pro
SVS 2039 PC Plus sub 12.3 (16hz tune)
PS3
Wii
Signal and Audioquest ic's
12 awg monster speaker-cable (bi-wired)
Belkin PF60 power conditioner
Monster power conditioner for sub -
The current PSW10 falls into your price bracket. You could probably find one on closeout/special from a number of online sources or local brick and mortar.
Good luck.
Christmas is overrated, buy now, repent later.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
I would recommend the Velodyn brand. The quality is very good.
Thank You
Ken Martin -
How BIC crams an at least $200 Bash amp into that H100 and still sales it for so low is beyond me.Receiver - Onkyo HT-R340
Front - Pioneer S-HF21
Center -Onkyo SKC-340C
Surround Back - Polk R15 <--Ticket to club polk
Subwoofer - Onkyo SKW-340 -
What about this Velodyne from frys.com?
http://shop2.outpost.com/product/4674948?site=sr:SEARCH:MAIN_RSLT_PGPioneer vsx-1120k, B&K Sonata series video-5 amplifier, Polk Rti8, Fxi3, Csi5, and HSU VTF-1 -
I tried a few budget subs last year, because I wanted a cheap sub for my garage.
Polk PSW-10 - Absolutely the worst performing sub I have ever witnessed.
Dayton Sub-100 A little better than the Polk, not musical at all though.
Velo VX-10 - Again a little better than the Polk, but not much output.
Yamaha YST-SW315 - This little sub suprised me, plenty of output, very tight, and seems imposible to bottom.
http://www.buy.com/retail/product.asp?sku=203025474&listingid=3853401&dcaid=17902
You may be able to do better on the price, I got mine from J&R last August for $184 delivered, through Amazon. -
stangjason wrote: »What about this Velodyne from frys.com?
Average price for that unit it seems.
http://www.google.com/products?q=VELODYNE+VX&btnG=Search+Products Less power than the H100Receiver - Onkyo HT-R340
Jason,
The only budget subs I'd recommend are the Bic H100, as mentioned or the Cadence XSub12...they are very similar in output, but the Bic's better. You really don't need to look any further. If you can increase your budget to $275, get the Elemental designs A2-250, flat to 20hz and quite a bit better.
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
+1 for the PSW 505.
+1 for DIY. With a little bit of work you can get a nice sub for very little $$$.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
