HD Audio?
Pepi28
Pepi28 Posts: 248
edited September 2007 in Electronics
I've been too busy lately to do any research on preamps with the ability to decode HD audio so I am asking anyone here if they know of any pre/pro's that decode the new HD audio formats and if so, which ones.:D
58" Samsung Plasma (on wall)(calibrated)
LSi15's front (modded xo's)
LSic center
LSiFX's sides
LSi7's rears
Sunfire Sig. 600 amp for 15's
Sunfire Sig. Cinema for C,S&R
Sony ES 3000 pre/pro
SVS 2039 PC Plus sub 12.3 (16hz tune)
PS3
Wii
Signal and Audioquest ic's
12 awg monster speaker-cable (bi-wired)
Belkin PF60 power conditioner
Monster power conditioner for sub
Post edited by Pepi28 on
    F1nut Posts: 52,000
    edited August 2007
    What new HD audio are you referring to?
  • Sherardp
    Sherardp Posts: 8,038
    edited August 2007
    integra, denon, onkyo, HK, sony. The integra is a dedicated pre/pro, the others I listed are AVRs.
    http://www.integrahometheater.com/model.cfm?class=Separates&m=DTC-9.8&p=i
    If your Sony ES gives you LPCM out with the PS3 while playing Blu-ray you wont benefit allot by having a new receiver.
  • cheddar
    cheddar Posts: 2,390
    edited August 2007
    Sherardp wrote: »
    Yep, current hdmi 1.3 players have a chip that implements the deep color part of the spec but not the undecoded trueHD and dts-ma streams to a pre/receiver. Could be that future players are released with this enabled via the proper chipset. But hd-dvd's advanced authoring mode of their disks disables this feature and your ps3 already decodes trueHD. All it needs is a firmware update to decode dts-ma and the outboard decoding will become unnecessary for you.
  • Pepi28
    Pepi28 Posts: 248
    edited August 2007
    Sherardp wrote: »
    Whenever I play a regular dvd on my PS3 the audio is output in digital meaning the blue light on the sony es lights up when 5.1 digital surround is being decoded. But when I put in a blu-ray disc and watch a movie the blue light does not come on and the LFE channell is not lit up. Also the sound is nowhere near as loud or full as when a regular dvd is playing on the PS3.
    LSic center
    LSiFX's sides
    LSi7's rears
    PS3
    Wii
  • Sherardp
    edited August 2007
    your PS3 should be able to decode the new HD formats, update your firmware and you should be seeing the blue light come on during playback. I know my 7100es does. Also check audio settings in the PS3.
  • surfntomm
    surfntomm Posts: 185
    edited August 2007
    i thought the ps3 could only output the new hd formats via analog outputs or am i mistaken?
  • Sherardp
    edited August 2007
    should also be via HDMI and Analog unless Im mistaken.
  • MikeC78
    MikeC78 Posts: 2,315
    edited August 2007
    The PS3 will only output the new audio formats via HDMI. There is no analog feature on the PS3.
  • BIZILL
    BIZILL Posts: 5,432
    edited August 2007
    MikeC78 wrote: »
    the ps3 uses the a/v multi-connector from the ps2 to utilize 2 channel analog out. from what i've read, anyway.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • MikeC78
    edited August 2007
    BIZILL wrote: »
    Thanks, I stand corrected.:) Wasn't aware of such hardware, and would never use it anyway.
  • LuSh
    LuSh Posts: 887
    Most source players will only support up to 5.1 True HD audio if it has any decoders at all. The industry is about to shift (yet again) with HDMI 1.3 receivers decoding and a number of player's finally being able to bitstream out TrueHD and DTS Master Audio. The receivers will be fully capable of 7.1...the home user also won't have to calibrate his source device every time he wants to listen to a disc switching between PCM and Bitstream out. This can get rather annoying.
    In regards to Deep Color; there is alot of confusion. The spec allows billions of colors but requires every link in the chain to fully utilize this option. For instance, the source player, receiver, panel and disc all have to be Deep Color compliant. Most panels are just starting to introduce 10 Bit color processing. Deep Color allows for up to 16 Bit. There are virtually no Blu Ray or HD DVD disc's which are authored using the advantages Deep Color has to offer. Some manufactures will internally process 8 Bit color information to 10 Bit.
  • rtart
    rtart Posts: 852
    Most HD DVD players will decode and output the HD formats via analog outputs. You can use 5.1 or 7.1 inouts on your receiver.
    My 7.4.4 DIY 4k Home Theater:
    Polk LSiM 707 L-C-R, LSiM702 side surrounds, LSiM 703 rears
    Polk LSiM 702s x 4 on the Ceiling Atmos speakers
    Subs: Eminence NSW-6021-6 tuned to 14Hz, NX6000D (front),
    2 x SVS PB12/Plus 2's (rear) miniDSP HD2x4
    Denon X3700H Emotiva XPA11 Gen 3
    XBox One X 4k & BD and streaming
    Panasonic UB-420 4k player
    HD-A35 HD DVD
    Oppo BD-103D for hirez audio
    Technics SL-D2 TT, Grado Gold Cartridge
    JVC DLA-RS2100/NZ7 projector
    Silver Ticket 135" microperf AT screen
    Berkline 090 electric recliners with Aura Bass Shakers
  • LuSh
    LuSh Posts: 887
    I dont know of an HD DVD player which has DTS Master Audio decoders built into it. Most have 5.1 analog output and not 7.1
  • kuntasensei
    kuntasensei Posts: 3,263
    I just got the Onkyo 705 receiver a couple of weeks ago. You name it, this sucker will decode it - TrueHD, DTS-MA, DSD - it's all there. It also lets you apply post-processing to Multi-channel PCM (which is what most devices are outputting via HDMI now), so you can use matrixing for 6.1/7.1, use the Audyssey MultEQ XT equalization, etc. with high-resolution audio. I don't have HD-DVD or Blu-ray yet (because I'm not getting into another format war and DVD still works for me), but DVD-Audio from my Panny S97 sounds amazing, and I actually like the 6.1 produced by applying DPL-IIx Music to the MCH-PCM stream. So jazzed about this receiver that I'm trying to find a pair of RTi38s or 28s to step up to 7.1.
    Also, the MultEQ XT calibration does wonders if you have a good subwoofer. My SVS 20-39CS+ now blends seamlessly with my RTi28s and CSi40, and sounds better than any theater I've ever been in.
    Not bad at all for a receiver you can find for around $650 with a little digging. Onkyo also has the 605 for around $400, which decodes all these formats but without any post-processing and with only Audyssey 2EQ equalization. Not sure if the 605 has pre-outs, but the 705 does and would make a pretty nice pre-pro on the cheap.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
