Pearl Tube Coolers
Midnite Mick
Midnite Mick Posts: 1,591
edited August 2007 in Electronics
I read in an add that these can "conservatively triple tube life". Does anyone believe this?
Thanks,
Mike
Modwright SWL 9.0 SE (6Sons Audio Thunderbird PC with Oyaide 004 terminations)
Consonance cd120T
Consonance Cyber 800 tube monoblocks (6Sons Audio Thunderbird PC's with Oyaide 004 terminations)
Usher CP 6311
Phillips Pronto TS1000 Universal Remote
Post edited by Midnite Mick on
  • Emlyn
    Emlyn Posts: 4,824
    edited August 2007
    I have a bunch of them but don't use them. Extending life of a tube would depend on the type of tube and the design of the circuit it's in. Some amp/preamp designs are a lot easier on tubes than others in terms of the heat produced in operation. If the tubes don't run all that hot, there's probably little reason to use the tube coolers. The main reason I don't use them in preamps is because the last set of tubes I had to replace had lasted five years (without the tube coolers) before a couple of them started getting a little noisy. However, I also found them to overdampen/dull the sound, which I didn't like. I do use them on driver tubes on a tube amp because the tubes do run very hot in that design.
