arcam alpha7 cd player and cd72 /compare
gtsdarts
what is the difference between the arcam alpha7 cd player and the arcam cd72 cd player ?both can be upgraded to the 8 or 9 .is the alpha 7 older ? it is also 100 dollars cheaper
gtsdarts
Post edited by gtsdarts on
I think it's just the difference in the D/A converters that are in the unit. I'm pretty sure that Aracm makes their CD players modular so you can upgrade them.
The Alpha series is not the current series, but it's badass none the less!LSi 9/C/FX
Arcam AVR-200
