Peerless in an SDA1??
geppy1
geppy1 Posts: 3,076
edited August 2007 in Vintage Speakers
I have SDA1s that have the silver faced SL1000. I do not have a problem with this tweeter and I have several speakers with it but am wondering if putting some Peerless in the SDA would offer anything? Has anyone done this?? Would a guy need to put 4 in? I have the RDO also but while smooth I do not think they have much extention and air.
Seperate question. The I think the SL1000 sounds pretty good but I know that speakers i have heard with the SL2000 sound thin and sligtly bright. Is it just my ears playing tricks? Is there a difference? Has anyone ever seen a response curve for any of these tweeters?? thanks,keith
Post edited by geppy1 on
    heiney9 Posts: 25,430
    edited August 2007
    1) The Peerless has different electrical and sonic characteristics than the sl1000 so other than an experiment I wouldn't recommend the swap.
    2) The sl2000 has a documented +5dB spike at about 13kHz which can be fatiguing and make the highs sound forward and adds a bit of "resonance" to certain vocals and intruments around that freq.
    P.S. To me the RD0's rule! Plenty of air and extension.
  • ND13
    ND13 Posts: 7,601
    edited August 2007
    If you decide to replace the 1000s with Peerless tweets...then change 'em all.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
