Will this amp be enough for the DB124??
dion_ysi
ive got an old school Precision Power Art Series A200 amp, 50w x 2 @ 4ohm, 200 x 1 @ 4 ohm, 400 x 1 @ 2 ohm.. Will this amplifier be enough to run my db124? if so which setup do you recommend, 200x1@4ohm or 400x1 @ 2ohm? is the db124 2 ohm stable?
Post edited by dion_ysi on
Yup.
Speakers arent stable at 4 or 2 ohm. Ohms is a measure of the load and the speaker is the load. Its the amp that has to be stable down to 2 ohms and it looks like your is (cause old school PPI rules!).
If you want to run your amp at 2 ohms, youll have to get the DB sub with dual voice coils. Hook them both up in parallel and youll have 2 ohms but be careful cause 400 PPI watts is about 800 to the rest of the world.polkaudio sound quality competitor since 2005
cheers.. i've got 2 of the PPI's, the other is the A204 which is the 4 channel im gonna use to run the 6.5" splits (db6501's) in the rear and the 5" db501's in the front kick panels of my girl's 86 bmw.. should sound sweet, hoping to finish it this weekend.. i seriously wish i could afford the SR's though.. thanks again mac..
