Dust caps pushed in
michaeljhsda2
michaeljhsda2 Posts: 2,201
edited August 2007 in Vintage Speakers
A pair of SDA's have some of the dust caps pushed in on the mid's. Will this affect the sound of the speakers? Should I be wary of purchasing them? Thanks for your opin.
SDA SRS 2.3TL's
SDA 2B TL's
Post edited by michaeljhsda2 on
  • Serendipity
    Serendipity Posts: 6,975
    edited August 2007
    You can replace them, but as Lasareath said first try using some duct tape to pull them out. If that still doesn't work double-sided tape usually works well.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • michaeljhsda2
    edited August 2007
    Hey guys, thanks for the tips. thinking of buying the SDA 1A on EBay . Always dreamed of buying the SDA SRS 1.2 tl ......but none for sale close to me. cheers.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • rskarvan
    rskarvan Posts: 2,374
    edited August 2007
    An L-shapped paper clip can be used to pull dented dust caps.
    Puncture (very small) the fabric of the dust cap and feed the "L-shape" inside - very carefully. Then, give it a gentle tug to "pop it out".
    I did this on a used pair of Baby Advents and they popped out and the puncture was virtually not noticeable.
    F1nut Posts: 51,796
    edited August 2007
    What a stupid idea! The tape trick works and you don't end up with a hole in your dust cap. DUH!!!
  • rskarvan
    edited August 2007
    Tape trick doesn't always work F1nut. If it did, then it would be a non-issue.
    F1nut Posts: 51,796
    edited August 2007
    That would be because you're using that socialist tape sold in Paris.
    F1nut Posts: 51,796
    edited August 2007
    Lasareath wrote: »
    LOL!!!
    Yeah, I cracked myself up on that one. :D
  • rskarvan
    edited August 2007
    French Engineering is pretty dang good. World's tallest bridge.
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2007
    There's a mini version of that style of bridge in Virginia, on I-295.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited August 2007
    dorokusai wrote: »
    There is also a mini on Rt 1 in Delaware.
    BTW socialist tape sold in Paris LOL!
  • rskarvan
    edited August 2007
    This bridge is taller than the Eiffel tower. And, not an inch of dust-cap-pulling-tape on the entire structure.
    F1nut Posts: 51,796
    edited August 2007
    They also built the "horse", worse than a Yugo. 'Nuff said.
  • rskarvan
    edited August 2007
    F1nut, please elaborate. What is a "horse"? I am familiar with many french cars including: Mercedes Smart, Renault Scenic, Peugeot, etc... but have no idea what a "horse" car is?
    F1nut Posts: 51,796
    edited August 2007
    It was a POS French car....the French version of the VW, only worse.
  • hearingimpared
    edited August 2007
    rskarvan wrote: »
    I heard it is just a picture of the bridge that it actually doesn't exist!:D :p
    F1nut Posts: 51,796
    edited August 2007
    Hehe.....
  • rskarvan
    edited August 2007
    French version of the VW would be the Citroen. A very quirky but well-loved car.
  • rskarvan
    edited August 2007
    That bridge is every bit as real as the WMD found in Iraq!!!
    treitz3 Posts: 20,012
    edited August 2007
    rskarvan wrote: »
    Nevermind..........
  • NeilGabriel
    NeilGabriel Posts: 1,487
    edited August 2007
    what was the question?
  • hearingimpared
    edited August 2007
    rskarvan wrote: »
    They found over 900 WMDs in Iraq. I guess they weren't nu clear so they don't count.
    Funny every intelligence agency in the world reported that So Damn Insane had WMDs but of course it was Bush who lied. WAAAAAAAAAAAAA:D :p
