Design Paramaters for 6511 and 6503 drivers For SRS 1.2's
gdsk39a
gdsk39a Posts: 28
edited August 2007 in Vintage Speakers
Anyone have the design parameters for the 6511 and 6503 drivers. I am trying to see if anyone makes a high quality drver out there rather than getting the Chinese crap.
G2
Post edited by gdsk39a on
    heiney9 Posts: 25,498
    edited August 2007
    gdsk39a wrote: »
    G2
    Polk makes replacement drivers. The info you are asking for is proprietary so you may not be able to find it, especially since those drivers are still in production from Polk.
    Just because a small amount of rubber was left in a mounting hole doesn't mean the drivers are junk. What happened to the original drivers in your SDA's? I've had numerous pairs of Polks from the same generation with absolutely no issue with the drivers.
    edited August 2007
    If you are having issue with new drivers you bought from Polk, have you talked with Ken Swauger? Polk has the best customer service bar none if they are aware of an issue.
