AMP for rti10 n Csi5
Vicedaddy
Would anyone have any suggestions for adding an AMP to power th eRti10's and Csi5 for my HT.....the yamaha HTR-6090 is my receiver. Or is th HTR-6090 alone enough to power the 10's the csi5 and RTi4's in the rear?
Post edited by Vicedaddy on
To answer your questions. The Yamaha is not enough to really get the most out of you speakers but it will work for low volumes. Adding an amp was a big improvement to my system and as you can see I have almost the same setup.
I, being a little biased, would recommend a B&K amplifier. You can pick up a used one cheap and even some of the lower wattage models have good current. What every you get it should have high current. IMO if the manufacturer doesn't list a spec for current I would pass on it. I also think for the RTi series a lower slew rate is better.
Check Audiogon and ebay is where I got the amp in my sig.AVR: Elite VSX-21TXH
Amplifier: B&K 7250 Series ii
Misc: Velodyne SMS-1
Mains: RTi-10
Center: CSi-5
Rear: Boston DSi460
Sub: SVS PC-Ultra
TV: Panasonic TC-P58V10
DVD: Panasonic DMP-BD60K -
Outlaw Audio, Parasound, Sunfire, Rotel, Adcom, & Nad are all good companies.
I would get a 5 channel 200wpc amp for all your speakers & be done with it.
You will get more bang for the buck shopping for a used one on Audiogon.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
