Foam or Polyfil?
viper_crazy
viper_crazy Posts: 3
edited August 2007 in DIY, Mods & Tweaks
Hi all,
I'm brand new to this forum, and relatively new to mobile/car audio. I did a search in the archives on what to use in my custom sub box: foam or polyfil.
The two that were of most help and interest to me were these ones:
http://www.polkaudio.com/forums/showthread.php?t=32824
http://www.polkaudio.com/forums/showthread.php?t=36687
They answered a lot of my questions to be honest. It seems like polyfil is the best way to go? How do I calculate how much I need and which wall do I put it on inside the box?
If anyone needs, I can make up a bit of a picture to post and show where the driver is going to be located in relation to the port...and for any one to critique if I can change it to get better sound. I have all the sides up, glued and screwed together except the top of my custom enclosure and have stopped there for now.
Thanks for your help.
Amp:
Sony Xplod XM-2100GTX, 100x2@4ohm RMS (250w Bridged@4ohm), 600 Peak
Sub:
Rockford Fosgate RFZ3412, 12", 4ohm, 50-150 watt RMS, 400 Peak
Enclosure:
Cheap Wal-Mart one bought to test out the sub i got off ebay (Custom one in the works)
Post edited by viper_crazy on
  • viper_crazy
    edited August 2007
    P.S.: I realize this is a home audio forum, but I thought I'd be able to get some answers, either way...
    Amp:
    Sub:
    Enclosure:
  • ben62670
    ben62670 Posts: 15,969
    edited August 2007
    I like poly fill. If you cab is too large you can use foam.
    Ben
  • viper_crazy
    edited August 2007
    So, do I just shove a bunch of Poly-fil into the box and let 'er fly? or is it best to adhere it to one of the walls of the box, if so, how do I determine the best wall to apply it to?
    Amp:
    Sub:
    Enclosure:
  • Deadof_knight
    Deadof_knight Posts: 980
    edited August 2007
    Viper its a pound per cubic foot for poly fill ( and keep it 3 inches from any port or the rear of the speaker me personelly I use fiber glass because you can shape it and staple it to the walls
    :cool: " He who dies with the most equipment wins Right ? "
    Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center
    ,HPSA-1000 18" sealed DiY home sub.:D
    Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables
