M10 vs R150 as surround Speakers
I'm looking to reconfig my 5.1 to a 7.1 setup. My front are RTI38's and my Center is a CSI30. And my exsting back surround speakers are the bose 201. I was woundering which speacker (the M10's or the R150's) would best match my exsting speakers? Oh, 2 of theses speakers would be replacing the bose. Any thoughts would be great.
Steve
Steve
Post edited by swd40 on
Both would work fine, but look around on CL for matching RTis 25s, 35s, 38s...the system as a whole will sound much better.
Combo rig:
SDA 1C, CS400i, SDA 2B
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
I'm not sure what u mean by a "cl"
When you refer to "CL" do you mean class?
so maybe the RTI28's would comlement the system
my guess is CL=CraigsList.com
My guess would be definitely...I heard some 35is recently and was impressed. I think you can find some older RTis for about the same money with greater benefit.so maybe the RTI28's would comlement the system
Combo rig:
PB13Ultra RO
BW Silvers
Oppo BDP-83SE -
Thanks for your input. Those bose 201's are in my opion weak on the highs.
I have another question - how would the Monitor 30's do with my RTI38's (fronts) and my CSI30 (center speaker)? just trying to figure out which speakers would work best in the surround. M10 vs. R150 vs. The monitor 30's
What speaker would replace the RTI38's and the RTI28's? I worry about ordering things on Ebay. You know the saying "Buyer be beware".
