hd dvd player help needed
sageleo
sageleo Posts: 170
edited August 2007 in Electronics
So I just bought a HD-DVD player, I have the sound hooked up with the 5.1 analogs, but I noticed when listening to a music cd that sound just comes out of my two fronts and nothing from the sub, I havent tried a regular dvd yet but am wondering if it will play through all the speakers or just the two fronts, and if sound only comes from the fronts is there a way to get sound from all of the speakers. by the way the player is the toshiba hd-a1. any and all help is appreciated.
thanks
T.V.- Sony KDL50W800B
Blu Ray- Custom built HT PC
Vizio Sound bar- S4221W
Post edited by sageleo on
  • BIZILL
    BIZILL Posts: 5,432
    edited August 2007
    not familiar with that model player, but have you gone through all the on-screen set-up menu's?
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • sageleo
    sageleo Posts: 170
    edited August 2007
    yep went through and did all the setting except for hooking up the internet to it still have to do that.
  • danger boy
    danger boy Posts: 15,722
    edited August 2007
    music CD's are only recorded in 2 channels.. left and right. so that's all you're gonna hear. left and right fronts. unless you set your receiver to play in 5ch or 7ch stereo.. or pro logicIIx
    play a DVD and see what happens.. if then you only get fronts. then check settings in your recevier and the HD player.
    PolkFest 2012, who's going>?
  • BIZILL
    BIZILL Posts: 5,432
    edited August 2007
    danger boy wrote: »
    DUH, i didn't even consider something so simple...thanks db. (assuming it's not an SACD)
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • sageleo
    sageleo Posts: 170
    edited August 2007
    I thought that I had tried that last night but it was kinda late so I might have missed something. I thought that since it was in 6 channel direct in I couldnt adjust between prologic or 5 channel or anything.
  • fireshoes
    fireshoes Posts: 3,167
    edited August 2007
    Can you change speaker settings in the HDA1 setup menu? Set the speakers to small and sub to on or LFE+main if it's available.
  • sageleo
    sageleo Posts: 170
    edited August 2007
    yeah I set all the speakers to small and sub to on, but I still don't get any bass when I'm listening to cd's. Could/should I have both optical and 5.1 analogs hooked up but into 2 different inputs. CD and 6 channel direct or is that not a good Idea?
  • WilliamM2
    WilliamM2 Posts: 4,808
    edited August 2007
    That's how it should be setup if you want multi channel from a 2 channel source.
  • sageleo
    sageleo Posts: 170
    edited August 2007
    so then I would use the 5.1 analogs for hd dvd's and the input would be 6 channel direct. for cd's I would use fiber optic and have it set to my cd input on my receiver? If thats is correct would I then receive bass from my sub?
  • WilliamM2
    edited August 2007
    Right. 6 channel direct is just as the name implies, DIRECT, no processing, no crossover settings, etc. With the CD input you will be able to set the crossover and sub output.
  • sageleo
    sageleo Posts: 170
    edited August 2007
    Hey thanks alot for the help I really appreciate it. Just got done hooking it up and reprogramming my remote now it works like a charm:)
