Adcom preamp question
NeilGabriel
NeilGabriel Posts: 1,487
edited October 2007 in Electronics
I just added an Adcom preamp to my 2 channel system. Assuming I don't want to use the bypass outputs, how do I choose between normal and "not" normal. I read the whole thing about bandwidth and dc current, and didn't get it. I'm running it with a NAD amp. Thanks.
Post edited by NeilGabriel on
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited August 2007
    Which Adcom pre do you have?
  • ben62670
    ben62670 Posts: 15,969
    edited August 2007
    Lab is full full range from like 1hz to 100hz. Normal is for amps that don't have tremendous range. I had a GTP-500. Too harsh. Excellent bass slam though.
    Ben
  • NeilGabriel
    edited August 2007
    GFP 565 with 3 different main outputs. I'm using normal because, well, it is normal.
  • ben62670
    edited August 2007
    I did the same. It puts less stress on amps that are trying to reproduce inaudible frequencies.
    Ben
    Ben
  • Music Joe
    Music Joe Posts: 459
    edited August 2007
    'Of 3 line outputs the only difference between 2 of them is, one is direct coupled and one has a bypass capacitor while both are connected directly after the tone control defeat and highpass filter switches.
    The 3rd is connected before these switches.'
    I use 'Bypass' because it has sounded best to me. Every time I switch to each of the others to play with tone & loudness I feel the sound loses some drive which the added controls can't compensate for..
  • larry207
    larry207 Posts: 4
    edited October 2007
    run it on bypass best sound for sure!
