speaker ? about sub in
moorefield
moorefield Posts: 23
If connecting the RT2000p's through "Sub Out" on receiver to line in on speakers...should i remove the gold jumper connectors on binging posts or leave them in place?
Post edited by moorefield on
  • del44
    del44 Posts: 686
    edited January 2003
    The owners manual says to remove the metal straps when using subwoofer output on receiver to line level input on speaker. I have used this method with my 2000's. However, I seemed to like the sound more, via speaker level inputs. But I also have dedicated subs to handle the lfe. The manual also states, that when using a dedicated subwoofer, speaker level input is recommended on the 2000's.
