PC Jerks
ben62670
ben62670 Posts: 15,969
You freaken guys. Now look what you made me go out and do!
I found some Carol 10/3, and a heavy duty right angle plug. I don't like straight plugs. Too much strain on the wire. I also found 125 amp sub panels for $37 with 3 20amp breakers. How do I explain that to the land lord?
Ben
Post edited by ben62670 on
  • hearingimpared
    hearingimpared Posts: 21,136
    edited August 2007
    You is a crazy bastage!
  • Bill Ayotte
    Bill Ayotte Posts: 1,860
    edited August 2007
    Tell him you want to upgrade the electrical system of the place and ask how much he is willing to put into the cause...He just might go for it.
  • ben62670
    edited August 2007
    I have a full 200 amp service ready to go in. I should just run 4 dedicated lines to my amps. Which I already have, but a sub right there would be nice with twist lock 30 amp plugs!
    Ben
  • engtaz
    engtaz Posts: 7,669
    edited August 2007
    It must be nice to have a Electrician's back ground. It makes DIY projects easier.
    engtaz
