Maranz MM 9000
Graymane
Graymane Posts: 92
edited August 2007 in Electronics
Does anyone know if this amp will drive 4 Ohm speakers? Thanks
Post edited by Graymane on
  • engtaz
    engtaz Posts: 7,669
    edited August 2007
    I would not use it. The owners manual shows only 8 ohms loads. If it does not state the it does a 4 ohm load it most likely won't. 4 ohm loads will stress a amp not made for 4 ohm loads.
    engtaz
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited August 2007
    I have one, and it'll run 4ohm speakers fine. I don't put much faith in the THX logo, but it is THX Ultra certified. One of the requirements is that it is capable of running 4 ohms.
  • Graymane
    Graymane Posts: 92
    edited August 2007
    Thanks for the input. Still trying to make up my mind on this amp or an Acurus A200x3 and running my rears with my receiver.
    heiney9 Posts: 25,432
    edited August 2007
    Graymane wrote: »
    Get the Acurus. Very nice sounding amp.
