I'm going to build a subwoofer...
VR3
Using two of the 15" versions of the drivers.
http://www.tcsounds.com/tc2000.htm
I want a tuning of like.. 10hz... (if not lower?)
It just has to be usable from 30-10hz... no real fidelity needed.
Box size - no limits. Ported preferably.
Will most likely use a Crown XTi4000 bridged to power it and use its crossover functions and so forth.
I dont have the nessicary tools to design this... so looking for some help!
Post edited by VR3 on
Vr3MxStyler2k3 wrote: »Box size - no limits. Ported preferably.
Don't let Ben see this, you'll end up living in a tent outside because he's convinced you to turn your bedroom into the box with 16 drivers, 2 ft wide ports that are 8 ft long driven by 50,000 watts of power.
That or just go the Marty McFly route and one huge freaken speaker.
Other than that, I got nothing. But good luck and I can't wait to see the results!I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius.
Pioneer VSX-816
Monitor 40's - fronts, bi-amped
Monitor 30's - surrounds
CS1 - center
PSW10 - I'll let you guess
Blue Jeans Cable - speaker cable
Daewoo 27 incher - one step up from a console
Sony Progressive scan DVD
XBOX
SOPA since 2008
Here's my stuff. -
I would tune it in the 14-15 hz range.A tuning of 10hz means the port will not be contributing much to the output.Vr3MxStyler2k3 wrote: »I want a tuning of like.. 10hz... (if not lower?)Testing
Testing
Testing -
Go to HT Guide DIY Forum and see what drivers people are using. they will have proven designs over there. If you want subsonic bass I believe there is a new 18" driver out.
design for TC2000
http://www.htguide.com/forum/showthread.php4?t=26418
Link to 18" driver
http://www.mach5audio.com/index-1.htmlSony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
I want to build a box, no sonotube...
If we could keep it around 30" deep.. 22" wide and height variable...
6-7 cu ft is totally possible.
10 hz tuning preferable...
I'd like to use those TC sounds drivers -- I like the fact it does 56mm xmax both ways and handles alot of power. So it should do good real low.
15hz tuning is fine too, with room gain it would hit significantly lower.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Just a heads up,but I would check with TC for the availability of the drivers you are interested in.It appears they are undergoing some big changes and may not be supplying the DIY market much longer.Testing
Testing
Testing -
will you be lighting this on fire after using it for a week too? :rolleyes:
PolkFest 2012, who's going>?
Also...
I wouldnt mind building dual subs -- alot more possibilities with that....
Two seperate enclosures, identical size, tuned the same, etc etc
Also would keep enclosure size down... and I could run them on two channel of amp...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3MxStyler2k3 wrote: »I want to build a box, no sonotube...
box/sonotube, it doesn't matter. you just need internal volume and port length to design a sub, that thread does that.
6-7 cubic feet probably isn't big enough to tune very low.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
That 18" driver you linked me to...
It says the rec. enclosure ported is 19hz tuning..
What size port does it use?
I like that driver, 22mm xmax one way, 800 watts, 18" driver...
Wouldnt mind using that.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3MxStyler2k3 wrote: »That 18" driver you linked me to...
Without simulating it I don't know for sure. it would almost have to be 6 or 8 inch port diameter for a driver that size.
Do some research at HT guide about the 18" driver if you're serious. I don't know if it's been used a whole lot. Sound Splinter drivers are also popular at HT guide and would be a good choice also.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
I emailed Mach Audio and asked what dimensions for the box and port width and length I would need for an 18hz tuning...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Sid -- for the record: you're crazy.
OK, build two boxes similar to the new VMPS VLAs. Imagine two gigantic towers with 4 15" drivers each, plus a couple of passive radiators. Wow.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
I think I have it figured out - maybe... assuming all my info is correct.
I entered the info from the subwoofer site into a box builder configuration...
The box program recomended for that woofer and my desired tuning a 215 liter enclosure, which came out to 7.62 cu ft
I then went to this site -
http://www.the12volt.com/caraudio/boxcalcs.asp#por
Entered in random numbers... 22" w, 31.125 h, 23.25" d to get to 7.6 cu ft
Then I went to their port calculator, for my desired tuning
To get a 18hz tune, I would need a 4" port, 10.75" deep
Does this sound correct?
Thanks- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I'm not crazy Brad...
I'm just insane... ok - I guess thats the same? haha
The larger subwoofer has the tone and accuracy above 30hz...
But Brian is a liar on bass response. The larger subwoofer TANKS at 30hz...
I have a 15db bump at 20hz to get my larger flat to 20hz... and the only reason I can do that is i have tons of power going to it.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Vr3MxStyler2k3 wrote: »I think I have it figured out - maybe... assuming all my info is correct.
Nope, 4 inch port is WAY too small for a driver that size. You're looking at 6-8 inch ports. 8 would be the better choice.
and with an 18 inch driver you're going to have to brace the living **** out of a box sub, thus making it bigger and bigger. You'd be better off building a sonosub with a driver that big.
This is the type of box construction you're looking at for a high excursion, large driverVr3MxStyler2k3 wrote: »I'm not crazy Brad...
you get that bump because your room is so small. power has nothing to do with it. You'd have to take it out into an open field with no boundaries to test true response.Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
http://www.polkaudio.com/forums/showthread.php?t=31077&highlight=diy+subwoofer
nuff said, build dual towers, multiple drivers, and enjoy
Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
I want to get this done for around... 1300ish dollars.
Amp + two subs will be around a grand... + wood, post, and ports - I assume around 300, give or take...
Thats the same price as the PB 12/2+ --- HOWEVER, I am going to make "two" subs basically... and have much more flexibility with crossovers/eqing and so forth. And the TC2000 driver should be better than the SVS driver. More power handling, more excursion. Etc etc
I have decided that whichever manufacture helps me design one first wins!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Hoosier --
Let me know when you're ready to sell those sub towers.:pHT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Hoosier --
I can deliver them when your ready.
RussDodd - Battery Preamp
Hoosier --
Hmmmm. How low do they go?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Hey wait they have already done this before didnt Micheal J fox had one of these in his room on back to the future , Oh wait that one blew up but I bet the box is still good....DOH !:cool: " He who dies with the most equipment wins Right ? "
Denon 3300 Adcom 535 BBe w/sub out 1 pr 4.6s 2 pr of 4 jrs Recent additions Samsung Lns-4095D LCD, Samsung hd-960 DVD, Monster HT-5000 Power center,HPSA-1000 18" sealed DiY home sub.:D
Black Laquer 1.2tl's w/ upgraded x-overs and Tweets BI-Amped with 2 Carver tfm-35's Knukonceptz 10ga cables -
http://cgi.audiogon.com/cgi-bin/cl.pl?homesubw&1192129327
These are really good for tuning low...size wise as well as braced extremely well...
I just picked up 2 15" TC-3000's......They increased their price 3 fold ..then lowered them again today...looks like the 15" TC-2000's are gone but the 12's are still avail.
http://www.youtube.com/watch?v=jbc4fW66U34The first rule of Fight Club is you don't talk about Fight Club
