Easy Way to Check for Common Ground Amplifiers
gdsk39a
gdsk39a Posts: 28
edited August 2007 in Vintage Speakers
Take your ohmeter and place the negative wire on the negative speaker post of the amplifer then take the positive wire and touch the amplifier chasis. If you get a 0 ohm reading then you have a common ground amplifier.
Cool?:cool:
Post edited by gdsk39a on
  • ben62670
    ben62670 Posts: 15,969
    edited August 2007
    Not how its done. You check for continuity between the negative speaker terminals. If you do have continuity you take a piece of heavy gage wire, and tie the two negatives together. No after saying that FIRST contact manufacture of your amp.
    Ben
  • gdsk39a
    gdsk39a Posts: 28
    edited August 2007
    Good catch I was refering to mono block amplifiers. You are correct for two channel amps.
    heiney9 Posts: 25,408
    edited August 2007
    Amp powered up or powered down or doesn't matter?
  • MikeC78
    MikeC78 Posts: 2,315
    edited August 2007
    heiney9 wrote: »
    Any resistance reading or continuity check is done with power off.:cool:
