pre/pro
NeilGabriel
NeilGabriel Posts: 1,487
edited August 2007 in Electronics
Do any 2 channel pre's come with built in DAC to process digital input? And would that then be a pre/pro? Thanks.
Post edited by NeilGabriel on
  • phuz
    phuz Posts: 2,372
    edited August 2007
    Good question. The only ones I've seen with DACs are home theater or multi-channel processors. I've never seen a 2 channel pre with a built in DAC.
  • AndyGwis
    AndyGwis Posts: 3,655
    edited August 2007
    I don't think I've seen this on stereo pre's either. Maybe a few select stereo receivers, but no straight pre's I can think of.
    If you have a good source, it should do the DAC job well enough. Or, get a decent, cheap player to use as a transport and add and external DACs. Adds flexibility, cool factor of owning a separate DAC, and sounds great. That's the route I went with. Player has all the features I want (SACD, headphone, etc.), Theta DAC makes redbook sound great, and all for less than the cost of a decent used stand alone player.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • WilliamM2
    WilliamM2 Posts: 4,807
    edited August 2007
    It only takes two inputs I believe, but this is a DAC linestage combo:
    http://www.positive-feedback.com/Issue25/monarchy_m24.htm
  • sucks2beme
    sucks2beme Posts: 5,682
    edited August 2007
    You'll notice the Monarchy DAC/pre review in this month's affordable audio!
    Looks like a fine unit.
    heiney9 Posts: 25,431
    edited August 2007
    There are other older Monarchy's that are line level pre's with DAC. The big limitation you'll find is limited inputs for a lot of gear.
  • NeilGabriel
    edited August 2007
    The reason I asked is that last night I hooked up my Rotel CDP to a HTR using the optial digital out to the optial input (which plays on DVD input). The sound was much superior to just running the rca connects to the HTR's cd input. That led me to believe that the HTR's (Yamaha) DAc was better than the cd player. Yes/No? so, I wondered if 2 channels pres had DACs with digital inputs for less than $15,000. I read portions of the article William2 linked...a tad over my head.
    tonyb Posts: 33,072
    edited August 2007
    May very well be Neil,on the Dac's.Don't recall too many 2-channel pre's with dac's in 'em.The 5-channel on up ones do for obvious reasons.Are you against getting a seperate dac? Or just trying to keep cost down?What are you looking to stay under dollar wise? You can get a 2-channel pre and a dac for less than a AVR.
  • phuz
    phuz Posts: 2,372
    edited August 2007
    What model Rotel CD player? What kind of interconnects were you using with it?
    *curious*
