Binding posts on Old SDA's
schwarcw
schwarcw Posts: 7,358
edited August 2007 in Vintage Speakers
Is it just me or does anyone find it difficult to mount the spades from the PS Audio line of speakers cables onto the binding posts of the SDA's? The binding plate is recessed into the cabinent, making it almost possible to get a straight on, flat mount of the spade onto the post. Banana's are the only thing that has worked for me.
Since cables don't make a difference, maybe I should wrap some micromotor stator wire (like from a 1/64 motorized road race car) around the posts and forget about it.:cool:
Carl
Post edited by schwarcw on
  • ben62670
    ben62670 Posts: 15,969
    edited July 2007
    Yes they are narrow, and bananas don't mount deep either.
    Ben
    F1nut Posts: 51,699
    edited July 2007
    Those binding posts are sub-standard, therefore I've replaced all of mine.
  • schwarcw
    edited August 2007
    Jesse, you bring up a good point and an idea. I have replaced my originals with Vampires, I know some folks like Cardas better, but I believe they have a similiar problem. There is a long shank on binding post which would be inside of the cabinents. Using a spacer, Like a hollow, hard plastic tube (cut to fit, or about six nuts mounted on the binding post on the outside of the mounting plate would extend the the binding post above the recessed area. I'm going to play around with that.
    Sal, those Monster spade connectors work okay, but I'm using the large PS Audio wire.
    Carl
    F1nut Posts: 51,699
    edited August 2007
    Carl, you could also try bending the flat spade creating a slight angle. I had to do that on something I owned at one time, it worked very well.
