PSW650 on external amplifier?
infinitiqx4
Is it possible to bypass the internal amplifier on the PSW650 and use an external amplifier? What would the load be, and how much power could I give it?
I may be acquiring a Parasound 1500 which is rated 205x2 at 8ohm, 315x2 at 4ohm, and 630x1 at 8ohm. How would this work?
Post edited by infinitiqx4 on
Anything is possable - u could rip the plate amp off and what not.
The real question is WHY???? -
its a very expensive subwoofer, if you get a amp use it for mains or something.. or get a better sub. what could be lacking from a dual subwoofer sub with a huge amp on the back??
the psw650 is a very nice sub, disableing amps and stuff kinda defeats the purpose.. its setup to handle said watts.. you add more you run into problems and sound is another issue.. you gonna add a crossover also? after you disable the inertsMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
I already have the PSW650. I am going with a 5.1, but may be getting 7 channels of amplification since I'll eventually go 7.1 when I have a larger room. Wouldn't the sub sound better with a larger, better amp? Is there a way to defeat the internal amp?
