Have you found God?
SolidSqual
I think he may be lingering around this website . . . . ahem(not what you think).
http://www.higherfi.com/spkrlist/speakerlist.htm
Post edited by SolidSqual on
I fixed it.
I listened to a pair of Audio Note at my local dealer. They are of course great and overpriced.
Fugly!!!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
Are those out of a cartoon?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I believe the Genesis 1.1 used the Carver ribbon. You know, the same one that Bobalou marketed for $2,700 in its most expensive version.
Yeah, why do all of them have to be so ugly? Does your taste change if you're suddenly able to afford stuff like that?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Some of those offerings are just awful looking (so I assume they have to have a sound that's almost other world).
This system, from TLG Acoustic,
looks as if it serves duty as a PA system at a roller-derby practice facility.
Gawwwwwd, that's ...... krunky looking.
There are some good lookers in the bunch, though. Those Von Schweikert VR11's look really sweet.Sal Palooza -
George Grand wrote: »I believe the Genesis 1.1 used the Carver ribbon. You know, the same one that Bobalou marketed for $2,700 in its most expensive version.
Yeah, and some schmuck was trying to sell for around 20 large a few years back......I guess the Corian wasn't such a big seller.
completley ridiculous. ugly...impractical....ridiculous.:rolleyes:I think Bananas are awesome fruit.
HT: Polk Audio RTi8 x2, Polk Audio CSi5, Polk Audio FXi3 x2, Velodyne DPS-12, Harman/Kardon AVR 247, Samsung 245BW Moniter/TV, Yamaha S1700 DVD/SACD, BJC Optical Cable, 12 guage speaker cable, Monster Standard Subwoofer Cable, Monster Lightspeed 1000 Optical Cable, Z-Line component rack, APC SurgeArrest 11-outlet.
http://www.polkaudio.com/forums/showcase/view.php?userid=81835
____________________
