Sl2500
dreinke
dreinke Posts: 1
edited July 2007 in Vintage Speakers
I need to know where Ican get some sl2500 tweeters for my polk audio monitor 12 speakers or the replacements
Post edited by dreinke on
    F1nut Posts: 51,805
    edited July 2007
    Call Polk at 1-800-377-7655. You want to order part # RD0198-1.
  • herbhead
    herbhead Posts: 6
    edited July 2007
    Hi,
    While we are at this, does anyone know where I can get an Interconnect cable? I need the plug/spade cable with both conductors connected straight through. They are for a pair of SRS 1.2TL. I have an isolation transformer ready to wire into the cable but I would also take an A1 with one in already it (and just keep my transformer).
    Thanks in advance for any help and replies.
  • NeilGabriel
    NeilGabriel Posts: 1,487
    edited July 2007
    herbhead wrote: »
    Hi,
    They are sold on ebay from time to time. There are also threads on the forum about constructing your own. Someone might also sell you one for a grand or so (with the speakers tossed in).
    heiney9 Posts: 25,447
    edited July 2007
    Just to be clear and you may already know this but you only need the AI-1 cable if you are using a non-common ground amplifier. If your amplifier is common ground the AI-1 is not neccessary.
    Also if if you have 1.2TL's the original tweeter is the sl3000 not the sl2500. The Polk replacment silk domes (RD0198-1) are an excellent upgrade. Neither of any original Polk tweeter's are avail from Polk anymore, but they do have suitable replacements that sound better in most people's opinion.
    Good luck and stick around and enjoy the show we get pretty crazy here sometimes.
