Do you think these speakers are worth the extra money
DMS44
DMS44 Posts: 6
edited July 2007 in Speakers
I am trying to decide between two different sets of speakers for my rear surrounds. The difference in price is going to be about $200.00 which isn't a problem but if it is money that I could use on other things that would be nice as well.
Here are the two speakers:
Polk LC65i
Polk LC65fx
I guess my question is will I notice enough difference between the two speakers to justify the extra money. I have heard the LC65i and think they will be fine for rears but will the two tweeters in the 65fx make that much difference?
Post edited by DMS44 on
    F1nut Posts: 51,700
    edited July 2007
    "Dual tweeters disperse the sound over a wide area-ideal for surround applications."
    treitz3 Posts: 19,958
    edited July 2007
    What speakers do you have for your fronts/center?
  • DMS44
    DMS44 Posts: 6
    edited July 2007
    I have LC265i and the LCi-C for my fronts and center.
  • phuz
    phuz Posts: 2,372
    edited July 2007
  • hoosier21
    hoosier21 Posts: 4,415
    edited July 2007
    spend the extra coin, you will be glad you did.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
