C500.1 Monoblock Circuit Board Repair
blindsidebryce
I have drilled a small hole damaging the amp. It is still receiving power but does not put out any sound to subs. I have damaged 301 and 203 chips on the circuit board (right behind the Remote plug in) and was wondering if there was anything I could do?
Thanks You
Thanks You
If you are handy with soldering iron, get a service manual from the manufacturer, figure out what parts you have damaged, order the replacement parts. Then repair broken traces and replace damaged parts.
Otherwise, contact the manufacturer for repair quote.
If the quote is too much, I'll buy it
'as is' - I need damaged monoblock that I can repair for my center. Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
