Will pointing the tweeter at the passenger be best for imaging?
big333john
I don't really want to use kick panels. I got big feet and thats where i put them when i drive:) i just want an opinion for tweeter pointing. For those of you who don't understand here is a pic
can someone move this to the right place, thanks in advance
Post edited by big333john on
It depends on the car, the off axis response of the tweeter and a bunch of other stuff.
The best thing to do is to buy some good double sided tape and try them in different spots and see which works best.
If youre not using time alignment or proper path length differences youre really not going to get any better or worse imaging. All it will really do is raise the stage.polkaudio sound quality competitor since 2005
thanks bud thats what i thought
