Both 2 Ch. and H/T question
weiser
weiser Posts: 55
edited February 2003 in 2 Channel Audio
I have purchased an Anthem Amp 1 and M&K sub that I wish to connect to my receiver Mains Pre-out for 2 channel listening.( Marantz SR6200 ) I also have a another sub connected to my receiver LFE for home theater use. What is the best way to connect the Anthem and M&K sub to the receiver mains pre-out. I thought of using a Y-splitter off receiver mains pre-out to the amp and the sub. Does this make sense or?
If correct, I will set bass management as follows in receiver, Mains-Large, Center-Small, Rears-Small, Subwoofer-On.
Am I correct here or?
Any help would be appreciated!
Thanks, Weiser
JVC AV48WP30 Widescreen TV
Marantz SR6200 Receiver
Panasonic RP-82 DVD
Sony SAT-A50 DSS DD Receiver
Sonic Frontiers Anthem Amp 1
Tara Labs-Axiom Interconnects
Tara Labs Digital 75 Co-axial
Kinima HiG2 Mains
Polk CS400i Main Center
Kinima KC2 Rear Center
Polk FX300i Rears
Polk PSW 350 LFE Sub
M&K V-3B Mains Sub
M&K V-2B Mains Sub
M&K LP-1S High Pass Filter
Ultralink Bi-wiring Thru
AR Pro Series Interconnects
Marantz RC2000 MKii Remote
Post edited by weiser on
  • weiser
    weiser Posts: 55
    edited January 2003
    Anyone have an answer!
    Help!
    Panasonic RP-82 DVD
    Kinima HiG2 Mains
    Polk FX300i Rears
    M&K V-3B Mains Sub
    M&K V-2B Mains Sub
  • TonyPTX
    TonyPTX Posts: 545
    edited January 2003
    Sounds like you know what you're doing and that I'll work!
    Damn....8 lines...I've gotta put my sig on a diet now....
  • weiser
    weiser Posts: 55
    edited January 2003
    Thanks for the reply TonyPTX!
    I suppose my main concern is how the signal coming from the mains pre-out will be affected by splitting to amp and sub. Not alot I can do at this point until such time as I purchase a Sonic Frontiers pre-amp. Later!
    Panasonic RP-82 DVD
    Kinima HiG2 Mains
    Polk FX300i Rears
    M&K V-3B Mains Sub
    M&K V-2B Mains Sub
  • Zen Dragon
    Zen Dragon Posts: 501
    edited January 2003
    Weiser:
    There have been many good discussions on this forum about alternative Sub connection methods. One of the most common is to put the sub in series with one of your mains. I will link you to a good recent thread, for more use the search forum function.
    The only concern with the method you are considering is creating an impedance problem by splitting out of your pre-amp jack. It basically puts 2 loads in parallel on your pre-amp jack. This may or may not be a problem.
    http://clubpolk.polkaudio.com/forum/showthread.php?s=&threadid=7329
    The Family
    Polk SDA-1C's
    Polk SDA-2
    Polk Monitor 10B's
    Polk LSI-9's
    Polk Monitor 5's
    Polk 5 jr's
    Polk PSW-450 Sub
    Polk CSI40 Center
    This is pretty f***ed up right here.
  • weiser
    weiser Posts: 55
    edited January 2003
    One other question. What is the best way to hook up the dvd player for 2 channel listening. I have the optical output of the dvd player hooked up to the receiver and listen to 2 channel music this way. Would it be better to connect off the analog connections of the dvd player to cd input of the receiver. If so, why?
    Thanks!
    Panasonic RP-82 DVD
    Kinima HiG2 Mains
    Polk FX300i Rears
    M&K V-3B Mains Sub
    M&K V-2B Mains Sub
  • shack
    shack Posts: 11,154
    edited January 2003
    It depends which one has the better DAC. If you want the receiver to convert the digital signal to analog, leave it the way it is. If your DVD player has a better DAC use the analog cables to the receiver and let the DVD player do the conversion. This is assuming that your receiver will let you do a direct analog pass-through. I'm not familiar with it so I don't know what it can do. If it can, try both ways and see what you like.
  • weiser
    weiser Posts: 55
    The converters in the DVD player are 96 KHz/24-Bit Audio D/A and the Receiver has 192 KHz/24-Bit D/A converters for the front L&R channels. Am I too assume that hooking the dvd player up, for 2 channel music listening, I should use the optical connection from dvd to the receiver. By doing this I would be using the D/A converters in the receiver which are better. Am I correct here or should I be using the 2 channel analog outputs on the dvd player?
    Panasonic RP-82 DVD
    Kinima HiG2 Mains
    Polk FX300i Rears
    M&K V-3B Mains Sub
    M&K V-2B Mains Sub
