Subwoofer connection - through the wall
tcrossma
I have a situation where I may need to move my sub to a side wall and I don't have the luxury of being able to run a cable anywhere above the floor to that location.
What i'd like to do, ideally, is put wall plates at both locations and run cable through the walls. Then use patch cables to connect from the wall plates to the receiver and sub.
The wall plates would have RCA connections I assume, and i'd use standard sub cable as the patches to the receiver and sub.
But what do I use in-wall between the two wall plates? Coax?
Thanks for any help anyone can offer.
tim
tim
Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH
Post edited by tcrossma on
Eliminate the wall plate connection. use a wall plate with a hole that you can run your sub cable through.[
So having a permanent and "finished" looking in-wall connection isn't a good idea? Is this because of performance hit that i'd get by having the multiple connections?
thanks,
timSpeakers: Polk LSi15
Phono Pre:PS Audio GCPH -
I'd go with the finshed look. I've compared my sub with a short direct subwoofer cable connection to my reciever with an in-wall setup with wall plates, connectors, and RG6 coax with many, many connections along the way and there was no audible difference in sound quality.
So it's just RG6 in-wall with RCA plugs on the wall plates then?Speakers: Polk LSi15
I used RG6 and a wall plate with a few extras, but any standard cable coax wall plate would do and then from the Parts Express website I ordered a coax to RCA adapter that I plugged the sub cable into.
Excellent, thanks for the info.
