is there an advantage to using monoblocks?
    mhardy6647 Posts: 34,917
    edited July 2007
    Yup.
    a bit of an extreme example (I'll try to find a more realistic one, from a hi-fi amplifier)
    http://www.vintage-radio.com/repair-restore-information/transistor_output-stages1.html
  • MacLeod
    MacLeod Posts: 14,358
    edited July 2007
    I like my relay race analogy better! :p
    VR3 Posts: 29,388
    edited July 2007
    Klaus at Odyssey said (not exact quote)...
    But basically --- lets say a stereo amp will run at like 40% effeciency
    Mono Blocks would run at 100% --- thats what he basically explained...
    I guess when you go to having multiple power supplies and caps, its hard to compare...
  • pearsall001
    pearsall001 Posts: 5,231
    edited July 2007
    I can see them now...mono blocks from McIntosh...MC501's to be exact. Would they sound better than what I'm running now? Who cares!!! They would just look so cool parked between my speakers. It's all about the WOW factor!!! :)
  • Early B.
    Early B. Posts: 7,900
    edited July 2007
    That doesn't make sense.
    Even if that's true, efficiency doesn't mean it sounds better. Class A amps are terribly inefficient, but...
    I'd love to participate in an A/B test with Klaus's Odyssey stereo vs. his monos. I'm guessing at normal listening levels, if there's a discernable difference, it's only a slight one.
    "God grooves with tubes."
    VR3 Posts: 29,388
    edited July 2007
    Well with a stereo Stratos Extreme vs Mono Blocks --
    Theres quite a difference in machiney... lol
    32 capacitors, 4 transformers vs 16 caps and 2 transformers...
    Thats quite a difference on its own... lol
  • Early B.
    edited July 2007
    Anothwer way to look at it is -- with monos, there's twice as many elements in the signal chain to f*ck up the sound.
    VR3 Posts: 29,388
    edited July 2007
    Eh possibly....
    But - Klaus uses small capacitor, quick charge and discharge and a very simplistic design...
    So while theres alot going on - theres not alot at the sametime...
    I always wanted Mono Blocks... Klaus was having some delay on parts - mine should be here around the end of July...
    woo hoo
  • Systems
    Systems Posts: 14,873
    edited July 2007
    Early B. wrote: »
    Yes,efficiency is determined by the amps class of operation(class A,B, AB, H D etc)not wether it is a mono or stereo unit.Class A is the least efficient and Class D the most with 80% + possible,but does it sound better than Class A?:D
    Testing
    Testing
    Testing
  • unc2701
    unc2701 Posts: 3,587
    edited July 2007
    Early B. wrote: »
    I agree that Sid's makin' no sense on the efficiency remarks, but with monoblocks, there's nothing more in the signal path. Zero. Overall the only additional parts vs a dual mono is another chassis; vs any other equivalent design, it'll only add another power supply.
    There's nothing magical about a monoblock, but it is one way to be sure that you've got independent power supplies.
    Backburner:Krell KAV-300i
  • Early B.
    edited July 2007
    unc2701 wrote: »
    OK, but what percentage of 2-channel amps are actual dual mono amps?
    IMO, monoblocks should differ substantially from dual monos made by the same manufacturer. What's the point of getting monoblocks if you don't stuff the chassis with lots of extra capacitance, a larger transformer, etc. than a comparable dual mono amp?
  • unc2701
    edited July 2007
    I'm speaking purely in terms of definitions. What's the advantage of a monoblock? Nothin'. It just means one channel per chassis. In practice, it's a different story. Just about all amps should be dual mono in my opinion, but monoblock guarantees one power supply per channel. Most manufacturers make their top-of-the line designs monoblocks, so they've got this aura, but in reality, just about any pair of monoblocks could be stuffed in a single well laid out chassis. (I'm sure someone is going to post some kinda monster amp... fine, there are exceptions)
    As always you gotta put your ears on any given component and see what it does for you.
    edited July 2007
    Most folks think that the stiffest possible power supply is best for hi-fi (not for a musical instrument/guitar amp, BTW). Separate power supplies is the best logical reason to use monoblock amps, as one channel's demands cannot cause "sag" in both. That said, harman/kardon, Kenwood and others long offered "dual power supplies" in even fairly modest single-chassis stereo gear, e.g., the venerable hk 430 receiver.
    EDIT: a photo of the innards of the "Twin Powered" hk630 is attached. Note the dual power transformers and profusion of P/S capacitors.
    A semilogical reason for monoblocks is that it eliminates crosstalk in the amplifier (although, of course, there could still be crosstalk in the analog source!).
    A quasilogical reason for monoblocks is that it permits the shortest possible signal path (cable run) for the high power signal... although this by necessity means a long cable (interconnect) run for the line-level signal. Is that better? :-)
  • Systems
    edited July 2007
    Early B. wrote: »
    These are the main reasons manufacturers build dual mono blocks.They can put bigger power supplies in the mono unit but it does not make the signal path more complicated.It just means that the gain stages have more power supply potential to draw from.An example would be the Bryston 7BSST (600 watt) mono block and the 4BSST (300 watt) dual mono unit.They both have the same size chassis but the 7B has 160'000uf's of capacitance and one 750va transformer feeding one channel where as the 4B has 54,000uf of capacitance and dual 500va transformers.http://www.bryston.ca/7bsst_m.html http://www.bryston.ca/4bsst_m.html
    Testing
    Testing
    Testing
