RL-p18 Sonosub Build
bob1029
Im going to be building a sonosub based on a 525L enclosure tuned to 13Hz, using a soundsplinter RL-p18 driver. Ive already ordered everything but stuff that Home Depot can supply, so the build will most likely begin next week.
Stuff that has already been ordered:
For the Subwoofer itself:
24" dia. 12' section of sonotube
Behringer EP2500
Soundsplinter RL-p18 D2
Some Binding Posts
For EQ:
Behringer DSP1124
Behringer ECM8000
Behringer XENYX 802
I may begin construction on the enclosure itself tomorrow...
Behringer EP2500
Some Binding Posts
For EQ:
Behringer DSP1124
Behringer ECM8000
Behringer XENYX 802
Sharp Aquos 32d62u
Onkyo TX-NR901
Behringer EP2500 - RTi12 - CSi5 - FXi5
Sonosub 700L tuned flat @ 14hZ
Onkyo TX-NR901
Post edited by bob1029 on
Try to find the sonosub.exe program to help you with the build. Also use WINisd to get the figures for the size of the enclosure, and port. I have built one with very good results. Pay particular attention to the WINisd program to make sure your cone isn't over traveling at any frequencies. This is where I messed mine up. At 35-40hz my sub would bottom out.
Here is a link to where my post is on my sonosub build.
http://www.polkaudio.com/forums/showthread.php?t=51533
Ben
