WHich center speaker
Nisqually Dave
I am now trying to figure out what I should do for a center speaker I have SDA SRS 2.3 for fronts SDA 1C for rears and at the present time I have CS 400i as center,
Should I just stay with the 400i, or what? the 400i is maxed out to keep up with fronts .
Post edited by Nisqually Dave on
Maybe add a 2nd CS400i in parallel.... just a suggestion.
How about a pair of SDA CRS+?HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Monitor 5's work very good for me with mt 3.1's.engtaz
I don't see the sense in a pair of CRS+'s when the supply signal is mono. Not sure if the SDA effect is engaged with a mono signal.
I thought about the second 400i, and my other thought was the CRS+'s but would you need two of the CRS+'s.
My only question about the 400i's also was the tonal guality matching with the 2.3's.
has anyone tried either of these ideas.
I appreciate your responses.
Dave -
LOL...nice HUGE front section...I have 1 cs400i and the thing is beyond huge.Pioneer Elite VSX-53, Polk RT800i fronts, Polk CS400i center, FX500i surround, Velodyne sub -
The 400i looks tiny compaired to the fronts
