Question about preouts on av receiver. (terminology)
impronto
Hello, my question is, on the preouts on my yamaha 5760, am I looking for an amplifier or a preamplifier to hook up in there? Thanks
Post edited by impronto on
Amplifier.
Hook the pre-outs on your receiver to a separate amplifier. Then you would be using your receiver as a pre-amp. -
hey phuz, thanks for the quick reply. Maybe you can help me out a bit, I have RTi8's, csi3, and rti'4s for the rears, and a 10' velodyne sub. What would you get for an amplifier in the $300 to $500 range? and this is a used price. Thanks
It sounds like home theater might be your priority. If so, you can get a good 5 channel amp by adcom, rotel, B&K, NAD, or various other seperate component manufacturers in that price range. Ebay and Audiogon should have plenty to check out.
Oh, and welcome to the forum!
can you give me some example models from some of those brands?
Here are some to check out.
http://search.ebay.com/search/search.dll?sofocus=bs&sbrftog=1&catref=C5&sacur=0&sorefinesearch=1&from=R10&_trksid=m37&sacqyop=ge&saaff=afdefault&fcl=3&frpp=50&nojspr=y&saslop=1&fss=0&satitle=%285+channel%2C+7+channel%29&sacat=14970%26catref%3DC6&sargn=-1%26saslc%3D2&sadis=200&fpos=77373&sabfmts=1&saobfmts=insif&ftrt=1&ftrv=1&saprclo=&saprchi=&fsop=1%26fsoo%3D1&coaction=compare&copagenum=1&coentrypage=search&fgtp=
Also Carver, Outlaw, Marantz, and Parasound would be good. Some may be outside of your price range. Patience and consistent looking will yield good results in the long run. Check local hi-fi and pawn shops and the Club Polk forums for good used/demo/consignment gear. -
That Nakamichi PA-1 amp is nice if you could get cheap enough.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
disneyjoe7 wrote: »That Nakamichi PA-1 amp is nice if you could get cheap enough.
Yeah I was looking at that beast too.
so this would have been a good one to choose? :
http://www.polkaudio.com/forums/showthread.php?t=54315
mm9000? -
mm9000?
Yup. That's a slick amp. I think there is one on ebay right now...... -
adcom GFA-555 will do as well as the others mentioned.engtaz
