Planning a Setup-Rate/Help
PolkFan1
I am currently trying to build a really good 2 channel setup. A setup that I would not want to upgrade for some time without spending tooo much money. How is this?
Rotel Rb-1080 Amp
Harman Kardon 3480 Receiver
Polk Audio Lsi9's
If there is anything that I can do to save money other than buying used let me know! Other gear or other recommendations etc. Thanks
Rotel Rb-1080 Amp
Polk Audio Lsi9's
Post edited by PolkFan1 on
Rotel Rb-1080 Amp
Polk Audio Lsi9's
If this is going to be for a 2 channel only, I'd recommend you change the H/K out of the system for a better 2-channel preamp.
I've heard mixed things about the Rotel, mainly it having difficulty playing 4 ohm speakers unless you blast them, I'd maybe look into an Adcom GFA-555 if you don't mind buying used, or one of their newer ones. I liked the sound and they are excellent for their price range IMO.
What are you going to use for a source?Lovin that music year after year.
Main 2 Channel System
Polk SDA-1B,
Promitheus Audio TVC SE,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
IXOS XHA305 Interconnects
Computer Rig
Polk SDA CRS+,
Creek Audio 5350 SE,
Morrow Audio MA1 Interconnect,
HRT Music Streamer II -
That's a mean amp, and sounded very nice when I demoed it....I agree that you should pick up a nice 2 channel pre, unless you already have that and plan on replacing it in short order after the purchase of the other two pieces...I am interested in what source you are using as well...
What do you mean source? I am kind of a newbie. I actually was just going to use the 2channel stereo harman kardon reciever and get an amp and just the speakers. What exactly does a pre amp do and what more do I need as you say what is my source?
By source, I mean CD player, DVD player, TT, etc....If you are getting an amp already, you don't need a receiver, you already have the power...A pre-amp is basically a receiver without a tuner and amplifier section....It is generally a lot cleaner sounding compared to using a receiver as a pre with a separate amp...
A source is simply that: a source for where you music will come from. It can be a CD player, a tuner, a turn table, XM Radio, HD Radio, etc., etc.
As for what a preamp does, it basically adds inputs and a volume control. The way systems are typically setup are, are like this:
Sources(CD PLAYER, Tuner, etc.) ---> Pre-Amp ---> Amplifier ---> Speakers
you can use your H/k as a preamp, however, it will color the sound a little bit more than a dedicated, audio only, preamp. The reason for this is due to the fact that Receivers are geared toward handling video and need a LOT more electronics to be able to handle it. The reason this can be bad is because all those electronics can distort the sound from the source, changing it.Lovin that music year after year.
Polk SDA-1B,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
Computer Rig
Polk SDA CRS+,
Edit: I knew I should have just waited a few minutes..
No need to be redundant.
Jason -
Jason
If you look at the time of the posts, you'd notice they were both typing at the same time. They weren't ganging up on you. -
I'm surprised I beat him....I type like ****.:D -
Wow, I didn't even notice last night. Ah well, Too many people trying to be helpful.Lovin that music year after year.
Polk SDA-1B,
Rotel RB-980BX,
OPPO DV-970HD,
Lite Audio DAC AH,
Computer Rig
Polk SDA CRS+,
