monitor-7's
jay-jay
jay-jay Posts: 11
edited June 2007 in Vintage Speakers
bought a set or monitor-7's but one driver is cooked. any info on buying a replacement or any info on upgrades would be appreciated.
thanks
jason
Post edited by jay-jay on
  • george daniel
    george daniel Posts: 12,096
    edited June 2007
    Welcome,,, what type of tweeters?--peerless?,,If not,Polk sells a silk dome replacement,,as far as the mids go, you could shop around e-pay,,or call Polk C.S. for replacements. Good luck,,,powered by the right gear, 7's can be very sweet.:)
    heiney9 Posts: 25,421
    edited June 2007
    Also be sure to pull the mid driver and get the correct model MW.......Polk used a few different models of drivers and they all have slightly different sonic and electrical characteristics.
  • jay-jay
    jay-jay Posts: 11
    edited June 2007
    the tweeters say silver coil dome??
    edited June 2007
    jay-jay wrote: »
    Ok so it's a tweeter that's bad. Do your 7's have a fuse on the back? If so, check it and make sure it's not blown. If no fuse, try swapping with the other good tweeter (I assume the other is fine). If the tweeter is in fact bad you need to get another one. The model # is sl2000. From time to time used ones are FS in our flea market. Polk makes a new replacement but it's not exactly the same and you *should* buy them in pairs for proper timbre matching.
    The cost is $48 each plus tax shipped, tell them you ar Club Polk member to get the discount.
  • jay-jay
    jay-jay Posts: 11
    edited June 2007
    both tweeters seem to work ok, no fuse on the back of the cabinet, the one driver is basically locked outward and will crunch if i try to push it inward. somebody must have cranked them pretty good, the one working speaker sounds ok but i figured i might as well change both drivers at the same time, the initial cost was only 15 bucks. so why not spend a little more and know they are both new.
    edited June 2007
    Alright, a little miscommuniction here, when you stated you had an "silver coil dome" I thought you meant that was the bad driver.
  • jay-jay
    jay-jay Posts: 11
    edited June 2007
    sorry, thats what is says in small lettering above the tweeter .
    edited June 2007
    The best thing to do is pull both drivers and make sure they are both the same model. MWxxxx. Once we know what drivers you have then we can proceed from there. Some of the odler drivers are no longer avail from Polk so you have to buy used, which for $15 you mentioned was a used driver.
  • george daniel
    edited June 2007
    is the bad driver the one in the middle?--midrange driver should have a model number stamped on the back--mw -xxxx,if thats the culprit,I would suggest that you change both,if you are buying the newer replacements.
  • jay-jay
    jay-jay Posts: 11
    edited June 2007
    both drivers are mw-6502 and that was 15 bucks for the set of speakers, gotta love yard sales.
  • jay-jay
    jay-jay Posts: 11
    edited June 2007
    what are the newer replacements like ?
  • jay-jay
    jay-jay Posts: 11
    edited June 2007
    do u have any information about the new replacements for a mw-6502?
  • george daniel
    edited June 2007
    no, but call Polk CS,they can tell you.sorry that I could not be of more help.
  • danger boy
    danger boy Posts: 15,722
    edited June 2007
    jay-jay, if you buy a replacement from Polk Audio.. get two of them.. even if you only need one.. and replace the MW6502's in both monitor 7's.. that way they'll have the same sound.
    PolkFest 2012, who's going>?
  • jakelm
    jakelm Posts: 4,081
    edited June 2007
    Just get 2 new mw6503 from Polk parts department and enjoy.
    Monitor 7b's front
    Monitor 4's surround
    M10's back surround
    Harman/Kardon AVR-635
    Oppo 981hd
    Denon upconvert DVD player
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
    Dont BAN me Bro!!!!:eek:
  • jay-jay
    jay-jay Posts: 11
    edited June 2007
    are the mw-6502 and the mw-6503 basically the same ?
  • fredv
    fredv Posts: 923
    edited June 2007
    If I remember correctly, the 6502 are only used by the speakers (such as Monitor 5 and 7) that have single mid-bass driver, and the 6503's are for speakers (such as Monitor 10, SDA's etc, RTA's etc) that have multiple mid-bass drivers. However, 6503 maybe the only replacement from Polk. Give them a call, if they OK, then it must be OK.
    -fredv-
  • jakelm
    jakelm Posts: 4,081
    edited June 2007
    jay-jay wrote: »
    Yes, to an extent, but I would never use just one. Replace both.
    Monitor 7b's front
    M10's back surround
    Oppo 981hd
    Mit RPTV WS-55513
    Tosh HD-XA1
    B&K AV5000
  • jay-jay
    jay-jay Posts: 11
    edited June 2007
    hey. are u famliar with any other old speakers say from the 70's?
