Home theatre operating temps?
linds6285
I am planning on system with Pioneer plasma tv, LSi speakers, Pioneer Elite & Outlaw amps. I would like to install it upstairs in my bungalow home but the temp goes up to 90 degrees during the day. In the evening temp is fine. The air conditioning does not make it upstairs! Is this going to be bad for the system or should i get window air unit and keep room cool all day? Can i get fans and run them all day on the equipment and skip the window unit? Nobody uses the upstairs until evenings when the room is cool but i'm concerned about damage during these summer months in Cleveland. Thanks in advance for your thoughts...
Polk LSi15 mains
Polk CS400i center
Polk FXi50 rear surrounds
Polk PSW1000 sub
Pioneer Elite VSX-81TXV AVR
(2) Outlaw 2200 amps
Sony DVP-NS75H
Pioneer 50" Plasma PDP-5080HD
Monster power HTS1600
Polk CS400i center
Polk PSW1000 sub
Sony DVP-NS75H
Post edited by linds6285 on
Are you going to run your equipment 24/7? IMHO, if you will be running it during just those cooler hours, you should be fine. Otherwise, get a window A/C.Panasonic PT-AE4000U projector for movies
Denon AVR-X3600H pre/pro
B&W CDM1-SE fronts
B&W CDM-CNT center
B&W CDM1 rears on MoPADs
DUAL NHT SubTwo subwoofers
Oppo BDP-93 Blu-Ray player
Belkin PF60 Power Center
Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room -
90 degress shouldn't be a problem, unless we are talking 90 degrees Celcius, or even 90 Kelving
As long as there isn't any moisture to go with the heat, I wouldn't worry about it. It isn't like you are going to be running the equipment during the daytime anyway, since you probably won't want to be up there in the heat.Tschüss
Zach -
You shouldn't worry, but 90 degrees is a bit on the warm side. Most audio gear will work fine in 90 degree temperatures, but other HT items such as video projectors need a COOL room to work properly.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
