Adding a 2nd sub of lesser quality a bad idea?
tcrossma
I have a Paradigm Ultracube 10 sub that I like very much, but i've moved to a new house and the new room isn't providing very even bass. I'm thinking about adding a second sub to balance things out, and I have a spare PSW10 lying around.
Will the PSW10, being a lower-end sub, bring down the overall quality of the bass or do you guys think it'd be ok to add it to the system?
thanks.
thanks.
Speakers: Polk LSi15
Amp: Pass Labs X-150
CD/DVD Player: Classe CDP-10
TT:Micro Seiki DD-35
Cartridge:Denon DL-160
Phono Pre:PS Audio GCPH
Post edited by tcrossma on
I always believe in trying first to see what your ears like it or dislike it. We can suggest something but it is you who knows what you like best. Try it to see is it works or does not. Good luckengtaz
What he said. It's better to try use a comparable sub or even a matching sub but mine don't match exactly (PB12 Ultra/2-PB12 Plus/2- new drivers) but they are close and sound great.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
like engtaz said. That's the best way to find out, just don't forget to play with the settings to try and blend the whole system together
Thanks everyone, i'll give it a shot.Speakers: Polk LSi15
Phono Pre:PS Audio GCPH -
what would people think if they knew i was running a ML dynamo AND an old sony 12''er? hahaAt Home:
Panasonic 42'' TC-L42U12 LCD
Pioneer VSX-80TXV
Toshiba HD-XA2
Sony PS3 - psn "metalguitars"
Xbox 360 - gamertag "giggidygiggidy"
Panamax 4300EX
Polk RTi8's
Polk CSi3's
Polk FXi3's. (x2)
Martin Logan Dynamo (x2)
Audioquest interconnects and wires.
Away From Home:
JVC HDR-50
stock system in new car for now:( -
I wouldn't try it unless you already have the Polk sub lying around. A lesser sub will provide lesser performance and may make your situation worse. If your room is the problem, then another sub isn't gonna fix it. You'll need to calibrate your system. You may need to invest in a bass EQ system.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
you also just might want to play around with placement of the Paradigm.
I've had the PSW10 and it was my first sub and it sounds like crap. It is way too booomy and easily distorts. I'd look elsewhere for improvements.
The weaker the sub, the more essential the placement. My PSW10 sounded like garbage just about everywhere but this one position that was a eyesore. In that position it sounded pretty respectable for what it is."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Well, the other day i was comparing my new psw1000 to my old velodyne cht8 and it was like night and day.....the velo sounded like rumbling mush.....the psw1000 sounded like a finely tuned base instrument....so there is no way i would include an inferior sub.....that muddy sound would contaminate everything you listen to in my opinion.B&W 804s mains
B&W HTM4 center
Polk PSW 1000 sub
Outlaw 990 Pre Amp
Anthem MCA 30 Amp
Monitor Radius 180 surrounds
Audiosource Stereo Amp for surrounds
Denon 2910 Universal DVD/SACD Player
Comcast DVR
Pioneer Elite 42" Plasma 940 HD
Harmony Universal Remote
Blue Jeans interconnects and biwires
Itunes Air Express
